Ac compressor bolt
Old Mar 29, 2012 | 06:20 PM
PRIMERED79 SHORT BED's Avatar
Ac compressor bolt
I went and fired up my ac today for the first time, and guess what no ac.
So I crawl under the truck to check the compressor out, and guess what I find?
The stupid face of the compressor had came loose and was sitting between my frame and the steering rack.
Just glad it didn't fall off the truck, now I need to put it back on, but I have no idea what size bolt.
Does anybody have a spare compressor or know the size and length of the bolt?
Old Mar 29, 2012 | 07:42 PM
Never mind went to OReillys and found it to be a 6mm x1.0
Old Mar 29, 2012 | 08:05 PM
Papa Tiger's Avatar
Papa Tiger
Something your asking and saying doesn't seem quite right, but if it works for you?
Old Mar 29, 2012 | 10:34 PM
FireMe's Avatar
FireMe
Don't forget to set the clutch gap. It has to be shimmed to the proper clearance or the clutch will burn up if it drags.
Old Mar 29, 2012 | 10:43 PM
How do I go about setting the gap?
And what should the gap be set at?
Old Mar 30, 2012 | 03:34 PM
There was a washer in the splined hole, is that the shim?
It's tight enough at the
Moment hopefully it won't fall off till I can get some lock tight after it.
Old Mar 31, 2012 | 10:43 AM
FireMe's Avatar
FireMe
The "washer" is a selectable shim. Spec is 0.014 to 0.026 between clutch and pulley.
Old Mar 31, 2012 | 11:24 AM
Great! Thanks for the help.
rowekmr
May 22, 2019 12:39 PM
britt
Sep 17, 2012 09:16 PM
pvatki
1983 - 2012 Ranger & B-Series
Sep 27, 2009 11:17 PM
Buggie
Sep 25, 2004 07:52 PM
