Oil Filter ?
Old Mar 28, 2012 | 10:34 PM
PRIMERED79 SHORT BED's Avatar
Oil Filter ?
When i leave for lunch or for home after work, my 400 knocks for a few seconds till the oil pressure builds then stops.
From what i searched, the oil filter could be allowing the oil to drain back into the pan.
I have a Wix on it now, and i forgot what the PO had on it ( just bought this truck two months ago).But it never did this till i started driving it to work.
So who makes a good filter that will keep the oil from draining back?
Old Mar 28, 2012 | 11:23 PM
VocaTexas's Avatar
VocaTexas
You're going to be hard pressed to find a filter better than a Wix. What brand and weight of oil are you running? How many miles does your engine have on it (approximate if you don't know for sure)? In case you didn't know, NAPA Gold Line oil filters are Wix filters.
I've got a '79 with a 351M, approximately 60k miles. I run the NAPA Gold Line filter (1515) and Havoline 20W50 oil. I run a ranch, so my engine spends lots of time at low speed. In the summer you could fry a steak on my hood due to the heat, so I feel that the 20W50 gives me added protection. Lighter oils get thin as water in our summer heat.
Old Mar 29, 2012 | 06:40 AM
Ohiocrewcab's Avatar
Ohiocrewcab
I thought Fram filters were the s#%t till I pulled one off the 460 I had and it was empty after 3000 miles. Now I use Wix on everything I run, I think they are the best out there. A little on the edge(just thinking out loud)your pick-up screen might be partially clogged causing oil to take longer to get to the rest of the engine. Sludge sucks!
Old Mar 29, 2012 | 08:24 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Originally Posted by Ohiocrewcab
I thought Fram filters were the s#%t till I pulled one off the 460 I had and it was empty after 3000 miles. Now I use Wix on everything I run, I think they are the best out there.~~~
3X on that! I agree that Wix is best.
Old Mar 29, 2012 | 08:33 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I haven't used the "orange can of death" in nearly fourty years. Personal experience and a VERY expensive lesson (over $6000 in damage 40 years ago) well learned.
Had a Fram hydraulic filter fail and it took out a Sundstrand variable displacement pump.
Haven't touched a Fram since.
Old Mar 29, 2012 | 11:25 AM
Ohiocrewcab
Hence the "HAD" in the statement. It lost all oil pressure once it was at temp with straight 50w in it.
Old Mar 29, 2012 | 12:47 PM
I think i will try a heavier weight oil.
I have to repair the oil pan any ways, and the gasket is leaking.
So as soon as i get the gasket from JBG, I will pull the pan and check the oil pickup.
Another ? will i be able to drop the pan without lifting the motor?
Its a rear sump pan.
Old Mar 29, 2012 | 01:02 PM
Blown 331's Avatar
Blown 331
I only run Motorcraft filters on my trucks. I have had a problem with a Fram.
Is your truck a 4x4? If so you can pull the pan with the engine in the truck pretty easily. I just did this on my 1979 with a 400 in my signature. I found a spun #2 rod bearing.
If you are gonna have the pan off I'd throw a high volume oil pump in it. These engines have poor oiling systems and are notorious for bad oil pressure.
Old Mar 29, 2012 | 01:08 PM
Ohiocrewcab
That I don't know. Make sure you have a hoist on hand just in case
Old Mar 29, 2012 | 02:09 PM
Mines a 4x4
Old Mar 29, 2012 | 02:13 PM
Who makes a good high volume oil pump?
So mine being a 4x4 I can pull the pan without lifting the motor?
It looks like there should be enough room to pull it without messing with the motor.
Old Mar 29, 2012 | 02:33 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Melling ; Be sure to call to make sure of the proper one for your application.
Melling M-84AHV - Melling High-Volume Oil Pumps - Overview - SummitRacing.com
http://motors.shop.ebay.com/i.html?_...+ford+oil+pump
Old Mar 29, 2012 | 02:38 PM
Blown 331's Avatar
Blown 331
Yeah you can pull the pan without lifting the motor. Like I said I just did this, Its only been a few weeks ago. I did put a jackstand under the frame on the right side so the suspension would hang down a bit but then the pan came right out.
The melling oldstyle posted looks good to me.
Old Mar 29, 2012 | 02:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
X2 (or 3) on Melling, it's a good pump.
Old Mar 29, 2012 | 03:35 PM
Is there any way I can tell what type of pump I have now by looking at it when I pull the pan?
And also on the eBay link, do you have to replace the pump
Shaft as well?
dave1969
1983 - 2012 Ranger & B-Series
Jan 26, 2017 06:39 PM
dave1969
Jan 24, 2017 02:48 PM
ihateminimumwage
Sep 15, 2006 11:33 PM
FORD352V8
Oil & Lubrication
27
Sep 24, 2004 10:18 AM
Gent
19
Jun 7, 2003 09:23 PM
