I read over on another site about the $5 dollar engine saver, which is basically swapping the defective OEM collant cap with an after market that will hold the 16 pounds pressure it is designed to hold. I had mine tested and it would keep falling to zero pounds, so I swapped it out.
The next day as I was leaving the house I had the CEL. I went back to the parts store and had them re-test the coolant cap since that was all I have done and now I get a CEL. The cap tested to hold the designed 16 pounds. I had them read the CEL code; P2262. Turbo boost. What??? I drove home and put the original OEM cap back on. drove about 10 miles making a couple stops. The light went off.
I know these sensors and everything are pretty sensative, but could higher coolant pressure have thrown a P2262?
No other problems were experienced; no smoke, power all seemed the same, no noises. I seemed normal.
Actually, I really didn't want to take it in because I am too cheap for them to come back and say "no trouble found". Caa-ching, that will be $100 bucks.
I just didn't know if anybody else had experienced a similar experience with the coolant cap?
I decided this just didn't make sense. I put the after market cap back on to confirm whether it was the cap that threw the code or not. I drove about 75 miles today, multiple stop and starts. No CEL, no codes, it ran great. I personally don't think the cap had anything to do with it.
Now to watch for another occurrance of the CEL to see if it pops back up again. A coolant cap throwing a booster code just seemed crazy.
Hope it is not the turbo. Obviously more than a $5 dollar coolant cap
