Door lock
Old Mar 31, 2012 | 12:28 PM
BlueMule's Avatar
BlueMule
Originally Posted by Ken_C
http://i293.photobucket.com/albums/m.../DoorLocks.jpg
Tech/Mods/info links used to be a sticky at the top of the main page but SOMEONE didnt like all the stickys and took them all down.
It's still there!
https://www.ford-trucks.com/forums/1...ostic-faq.html
Old Mar 31, 2012 | 12:54 PM
oldbird1965's Avatar
oldbird1965
I have no idea of why SOMEONE would do that?! (Cookie) Is it to make it harder to find information or so we ask more questions to keep the forum alive?
Old Mar 31, 2012 | 02:53 PM
91 Dually's Avatar
91 Dually
They were all combined under the 2nd "read first" heading at top.....
Old Apr 1, 2012 | 08:09 PM
bearhugger's Avatar
bearhugger
Thanks for the drawing Ken,i got all windows working and the passenger rear door lock working ,think i had more then one problem,bad wire connection in driver side wire bundle and the door lock was hard to move by hand,sprayed with wd 40 and now working ,still have problem with driver rear door,will hit this later,thanks again guys.
Old Apr 1, 2012 | 11:04 PM
Ken_C's Avatar
Ken_C
Sweet! yep I had to soak mine in wd40. matter of fact i soaked the lock assembly too. not sure if OEM lock poppers are available still but my rear drivers side is really weak. some times have to hit it 2 or 3 times to get it to unlock. but i gotta think any lock popper would work.
Old Apr 1, 2012 | 11:10 PM
psd96's Avatar
psd96
Ive got the same exact problem, same door. And the lock on the rear passenger door is no longer powered. Thanks for the help
Old Apr 2, 2012 | 10:43 AM
TxTrucker's Avatar
TxTrucker
I had the same problem as well. There is a pigtail that plugs into the bottom of the actuator. I unplugged mine and cleaned the contact area and they worked just fine. Not sure this will solve the problem in every case though. The aftermarket actuators are available through O'Reillys, Autozone, Advance, and I'm sure most other parts stores.
The problem you may run into is that most of them only show the ones for the front doors but if they will dig a little the back ones are listed as well. Most of the old school parts guys are a thing of the past and if it's not right on the screen then you will most likely get the "we don't carry it" answer.
On that note, and I'm sure most of us know, you can go onto their websites and look the parts up yourself. It's always better to go in armed with the part number yourself to see if they match. Just an FYI.
Old Apr 3, 2012 | 07:11 PM
bearhugger's Avatar
bearhugger
OK guys, all door locks and windows working ,checked the driver side lock and found the connector on motor was completely loose,guess it has been like this ever since i have had it, plugged it back in and it worked fine.First time everthing has worked,couldnt have done it without all the help i have had. Again thanks. JIM
ShelbyHauler
Dec 27, 2017 03:26 PM
hellmary
Aug 10, 2013 06:23 AM
kent521
Feb 22, 2011 11:28 AM
fifty-two_f1
May 13, 2010 09:42 AM
muchomota43
1997 - 2003 F150
Jan 27, 2004 11:01 AM
