Fuel problems when starting
Old Mar 28, 2012 | 03:54 PM
81ChopTop's Avatar
81ChopTop
First off, I have a '86 F-150 with a 351w, an Edelbrock 1406 carb, mechanical fuel pump, Weiand Stealth intake.
When the truck sits for a couple of days, it takes a lot of cranking and pumping to get it going (once started, it runs great). If it sits for just a couple of hours since last run, it starts right away.
Could it be the fuel pump letting the gas siphon back? Do the pumps have a check valve in them? It's kind of embarrassing cranking on it that long.
If I remember right, it got a new pump a couple years ago, maybe a bad one?
Another question, what can I do to keep more heat out of the carb? I get a little vapor lock when the engines real hot.
Old Mar 28, 2012 | 04:18 PM
ctubutis's Avatar
ctubutis
I will bet you this is your problem, all the gas in the bowl is evaporating.
The carb on my 400 used to get so hot I could hear the gas boiling, and there were little wisps of white "smoke" coming from the "smokestack" (breather) on top.
I got one of these, a wooden carb spacer, to keep the heat away.
Old Mar 28, 2012 | 04:56 PM
81ChopTop's Avatar
81ChopTop
ctubutis - What you are saying sounds like what my problem is.
I'm going to ramble a bit here.
This is the spacer that's on it right now - 1"
I don't remember what center is in it though.
The problem got better when I installed this, compared to the all aluminum one. I also re-routed the fuel line from the pump to the carb. to give it a little more "air".
Here's kind of a comparison - On the '83 I had, basically the same engine, same carb, 4spd. I had a 3 row copper/brass radiator in it. The gauge almost never went over 1/4 way up. Right now on the '86, it has a one row aluminum/plastic, the temp is always at or just above 1/2. This always concerned me as it seemed to run too hot like the radiator could barely keep up, but never over heated.
I have from the '81 a 4-row, extra cooling size, brass/copper unit I've been debating putting in.(Cost me $300 to get built so might as well use it) I would just have to put some holes in the core support for the lower mounts and use the older top mounts ( I saw it done on a truck in the junk yard and everything fit nicely). Also have a nice set of electric fans to use.
If I could keep the engine temps down more, this may also help with the fuel issue? I'll look into the wood and phenolic spacers and pick one up too.
Old Mar 28, 2012 | 05:04 PM
ctubutis's Avatar
ctubutis
I wouldn't at all trust a factory temperature gauge, wouldn't make decisions based on what it was telling me.
How many degrees is "O"?
Old Mar 28, 2012 | 05:24 PM
81ChopTop's Avatar
81ChopTop
I hear what you're saying. I do have an Autometer gauge here also I could hook up and take it for a "typical" drive and see just where it's at. I'll do that first.
I do need to do something about the radiator that's in there though. It has a small leak (stupid o-rings) when it warms up, but when hot, no leaks.
Old Mar 28, 2012 | 07:19 PM
bruno2's Avatar
bruno2
Gary knows what all of the letters represent as far as temps go.
Old Mar 28, 2012 | 08:07 PM
81ChopTop's Avatar
81ChopTop
Did a little test. I hooked up the Autometer gauge and did some running around.
Results:
Outside air temp - 45 degrees, approx. 20-25 minutes (not much traffic)
After about a 5 minute warm-up
Sensor located in intake right by the thermostat (output to rad.).
Right after about 12-13 miles on the highway
After 10-12 miles through town
After idling for 10 minutes
After 10 minutes of heat soak
So, now I know actual temps (and truck gauge positions at given temps), it gives me a little different perspective. When first on the highway, it did peak to about 205 degrees, but as soon as the thermostat opened, dropped down to 180-185. Once the cooling system was fully up to temp, it never went above 200 degrees. Even after heat soak, I still wasn't seeing temps I thought I would.
I would like to repeat the same test when air temps are 70+ degrees, just to see what happens.
So, the radiator is keeping up with the heat. Yeah, yeah, I was wrong. I'll admit it.
Besides the different carb spacer, what else can I do to keep the heat off the carb?
Old Mar 28, 2012 | 08:19 PM
ctubutis's Avatar
ctubutis
What engine?
Old Mar 28, 2012 | 08:51 PM
81ChopTop's Avatar
81ChopTop
It's got a 351w.
Edward Michael
Sep 17, 2018 02:42 AM
bigfoot22
Jun 11, 2016 09:05 PM
81ChopTop
56
May 1, 2016 09:44 PM
clinkfield
Dec 11, 2013 01:15 PM
lilsmokey
24
Oct 26, 2012 11:07 AM
