7.3 intercooler options
Old Feb 8, 2013 | 03:57 PM
  #61
drummerjason's Avatar
drummerjason
Smile
Originally Posted by RÖENTGEEP
In this link you can see my set up and maybe helps you a little:
https://www.ford-trucks.com/forums/9...installed.html
Hey thx for the link, I just started looking into doing this and all the pics and answers really help. Your truck looks like a clean straight forward install. Now if i could round up all the parts for a cheap install too.
Old Nov 8, 2013 | 11:31 AM
  #62
nossliw's Avatar
nossliw
Originally Posted by drummerjason
Nossliw, looks like you did your homework a little bit. Yeah I agree with you on the intake plenums, might as well go 3" since you have 3" coming to it in pipe. Where did u get the 3" elbows for your ic pipes from? I haven't looked around much for someone that makes em/sells em....are they factory pieces. Also, so you used 99.5 to 2003 intake 3" plenums i take it. Sorry for all the ?s, thx again.
Its been a long time since I have been back to this thread but I'm sure you have answered these questions by now.
I did 3" since I will be putting a S366 in next winter when I pull my tranny to rebuild. I also did it for other reason but i think I covered that earlier on. Cheapest place to get 3" bends would probably be Summit. I actually bought mine here locally at a hot rod shop I used to work at...only guy in CO who has a mandrel bender and knows how to use it properly.
I used a 99.5+ X pipe and just cut off the hot side and fabbed my own piece to work with the stock turbo, till i remove it and can use a different flancge and 3" tubing with the 366. It would be just as easy to fab your intake 7 though out of 3" U bends. I used the flange off the original pipe for the stock turbo.
Hope this helps... you probably have already done this install.
Old Aug 31, 2016 | 12:59 PM
  #63
ian.mck's Avatar
ian.mck
Need the intercooler pipes for 95 7.3
Need contact info for the guy that makes the intercooler pipes
Old Sep 1, 2016 | 03:36 PM
  #64
BBslider001's Avatar
BBslider001
Might want to start a new thread. This one is 3 years old.
Old Sep 1, 2016 | 07:14 PM
  #65
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Welcome to the forum, but I agree with Byron.
Old Sep 2, 2016 | 09:47 AM
  #66
Bob_T's Avatar
Bob_T
Hey, it's three years old and it's still a very good thread. The bump got me to see it and read it and I learned a lot.
Old Sep 2, 2016 | 10:48 AM
  #67
nossliw's Avatar
nossliw
Sure seems like much more than 3 years ago...incredible how much you learn in that duration...
mid7.3
Mar 12, 2009 09:41 PM
jimwilsonmasonry
Apr 26, 2008 07:52 PM
robjs111
Feb 21, 2007 05:12 PM
mtgrzlyman
Jun 1, 2006 12:27 PM
mtgrzlyman
16
May 13, 2006 10:03 AM
