Hub assembly ?
Old Mar 28, 2012 | 01:06 PM
bulla's Avatar
bulla
Hub assembly ?
We were changing a rotor, caliper, and pads on a '99 F350 dually. The problem was with the new rotor and hub spacer bolted on the frame for the caliper would hit the rotor and lock the rotor. The old one had signs of wear from this issue. Now the only thing I can see is the hub face like where the rotor fits against is out about 3/16 further than the pass side. The real question here is is the hub just spaced out a lil further cause it's the wrong one? Or could it be the hub is going out and somehow is walking over? The problem started a day after it sat and he noticed the truck would pull to the right, but the left rotor was steaming hot. The hub feels tight and rolls smooth. No real signs that the hub is going out.
Old Mar 28, 2012 | 01:12 PM
PaysonPSD's Avatar
PaysonPSD
Sounds like a Late 99 rotor and an Early 99 hub. E99 front hubs can go out to Mar or April, 1999. When I got new rotors for my E99 I had to specicically order rotors for an E99.
Rovernut
Jan 9, 2013 05:36 PM
bmxstreet15
13
Feb 16, 2009 02:51 PM
89fourx4
Jan 18, 2007 07:48 AM
threefiftyone
Aug 30, 2004 05:27 PM
DJack
1978 - 1996 Big Bronco
Jan 11, 2004 07:57 PM
