Help ASAP!!!!!
Old Feb 15, 2009 | 01:37 PM
bmxstreet15's Avatar
bmxstreet15
Help ASAP!!!!!
I am in the process of putting rotors, calipers, and pads on my 97 F350 with manual hubs. I have the hub/rotor assembly out. but I dont know how to seperate the two! Can someone point me in the right direction?
Old Feb 15, 2009 | 01:47 PM
tjbeggs's Avatar
tjbeggs
Take a big hammer and pound the wheel studs out from the outside inward then you can seperate the hub and rotor. hit them hard. One big hit does less damage than many lite hits
Old Feb 15, 2009 | 02:04 PM
bmxstreet15
I got the studs out but cant seperate the hub from the rotor.
Old Feb 15, 2009 | 02:31 PM
tjbeggs's Avatar
tjbeggs
I take the same big hammer and set the hub/rotor on the back of the rotor with the outside (where the lock out goes) of the hub facing up. Then take a block of wood and place it across the hub and hit it HARD with the hammer. It will drive the hub down and out of the rotor. If the seal side of the hub hits your bench then block it up so it has room to get driven down.
Old Feb 15, 2009 | 07:02 PM
bmxstreet15
well after much frustration, i drove them out with a BFH. Wow!!! I am glad I wont have to do that again for another 10 years!
Old Feb 15, 2009 | 07:25 PM
MADVAN's Avatar
MADVAN
Tj
That was a job for Rick.
Bored, the 500 bumbed me!
Bill
Old Feb 15, 2009 | 07:36 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by MADVAN
Tj
Bill
Just stuck and needs hittin with a hammer!!
Who won the 500?
Old Feb 15, 2009 | 07:44 PM
BlueMule's Avatar
BlueMule
Gettin them out was the easy part, now ya gotta putem all back in again.
Old Feb 15, 2009 | 11:57 PM
bmxstreet15
Putting them back together wasnt too bad. But I do have one question, How tight should the hub nut be? The first one puts the load on the bearing and the second just holds that lock washer in right? I dont want to get them too tight but I dont want them too lose either. BTW, Thanks for those diagrams Tim!
Old Feb 16, 2009 | 09:01 AM
bmxstreet15
any ideas?
Old Feb 16, 2009 | 10:03 AM
powrstrkr's Avatar
powrstrkr
Who won the 500?
I didn't watch but it was on the news. There was a big pile up mid race so they ended it early. Matt Kenseth won it.
Old Feb 16, 2009 | 10:36 AM
cowmilker08's Avatar
cowmilker08
The pile had nothing to do with why they ended it. They ended the race becuase of the rain.
And just for the record i don't think Jr. did anything wrong becuase he beat vickers to the yellow line, then vickers ran Jr below the line and Jr unintentionally hit the rear bumper of vickers car. if it were intentional i think Jr would have hit him farther up near the rear tire.
Old Feb 16, 2009 | 10:47 AM
bmxstreet15
So how about my axle nut torque?
Old Feb 16, 2009 | 02:51 PM
BlueMule's Avatar
BlueMule
Torque the inner nut to 50 ft/lbs while rotating the disc and then back it off 90*
The lock nut can be flipped over to get the pin on the inner nut to line up with the holes
Outer nut gets torqued to 160-205 ft/lbs
