Sponsored by: Kumho
one-piece or two-piece
Old Aug 28, 2004 | 12:31 AM
threefiftyone's Avatar
threefiftyone
Question one-piece or two-piece
Help! How Do I tell If I have one-piece or two-piece hub and rotor. Does the one piece have a welded seam between the rotor and hub casing?
92 Bronco 4x4
Old Aug 28, 2004 | 06:12 PM
SoCalDesertRider's Avatar
SoCalDesertRider
On a 2-piece hub/rotor, the rotor typically bolts onto the hub via the wheel mounting studs. On a one-piece, the wheel studs thread/press directly into the rotor/hub center. Most vehicles have a one-piece setup.
Old Aug 29, 2004 | 03:39 PM
threefiftyone
Thanks, I figured it out. Once I tapped out the studs, the hub fell off the rotor. It just wouldn't budge while on the truck. I was reading my Ford Truck Owners Bible, and they said that one-piece rotors/hubs, dissipate heat a lot better too.
Old Aug 30, 2004 | 05:27 PM
andym's Avatar
andym
All the 4x4's I've ever seen are two pieces, the 4x2's are one piece.
