Thing these will fit???
Old Mar 28, 2012 | 11:36 AM
stephenok711's Avatar
stephenok711
Hey guys,
I've read a lot of posts about being careful with purchasing rims off craigslist because of different offsets and not fitting the hubs.
Do you guys think these wills would fit?
HELO RIMS CHROME
The seller said the rims are 8x165 or 8x6.5 with a hub center of 122.5.
I know that the hubs on dodge wheels are smaller stock so does anyone know exactly what specs the hubs are on 1978 f250 2wd?
I would measure except my truck is a couple hours away in a shop.
Any information is greatly appreciated.
Thanks.
Old Mar 28, 2012 | 01:22 PM
miottimouse's Avatar
miottimouse
711 they should work the issue i have found for all 8 bolt rims is if they are stock rims from a chev they are the rims that have a smaller hub compared to the ford/dodge rear dana 60/70 and have to be dremmaled out slightly to fit the ford check some of the online tire/rim sellers,find that rim and check the offset i have seem that same rims lots of times just make sure the seller knows for sure they are 8 on 6.5 and not 8 on 170mm those are for the later trucks 96 and up and will not fit! and most time people sell those 18" rims due to tires being very pricey personaly unless you are looking for that "new style big rim/low profile look i would go with a 16" rim hope this helps
Old Mar 28, 2012 | 03:04 PM
stephenok711
Thanks for the info.
Big Big Blue
Mar 3, 2018 11:17 PM
'78f350
Jul 3, 2014 10:51 PM
SC78f150
Jan 15, 2014 07:56 PM
im2tall33
15
Jan 14, 2010 02:55 PM
Ervin
Sep 7, 2005 02:08 PM
