I feel embarrased for not being able to figure this out but... I cant fint the last bolt/s that hold on the outer fender. I took off the ones on the top and the one underneath but cant find were it bolts to the cab??
Thanks guys!
Look in the space where the door bolts to, there is a little cavity there to access the bolt. The door has to be open to get at it. Good luck.
You are thinking bumpsides......These are accessed through an opening in the A pillar.
The mid point cowl to fender bolt is in a opening on the kick panel just under the where the dash meets it. It may or may not have a cover with a single screw holding it in place.
You will need a long extension and a socket with a magnet or tape in it to retrieve the bolt. These often break the J nut due to corrosion. If this happens it holesaw time in the fender to access it.
Garbz
You're right....they all run together after a while. I'm currently parting a slick, a bump, and a dent.
