My V code and B code swap
Old Mar 29, 2012 | 10:10 PM
jwronski's Avatar
jwronski
Thanks for the info. reps sent. I am picking up my V codes this weekend and will need to start planning on the additional parts needed so I will be ready to start soon. Need to send the kids to friend's houses so they won't be hearing the lovely sounds of busted knuckles and colorful language that day!
Old Mar 29, 2012 | 10:17 PM
Forest's Avatar
Forest
Originally Posted by 9905
That Sir, is one good eye you got. Yes, it is our 1984 34W triple axle Avion.
It is another project that I have been working on for a year now. We sold our 2009 38 foot Jayco fifthwheel for a smaller trailer with no slides. Our rv buddies think we are nuts. Have a few more projects to make it real nice but I just put 6 new Maxxis tires on it Tuesdays so the funds dedicated to it this year are low.
I am really excited to get the Hensley installed. I am really hoping and expecting something amazing.
Hey, good luck with that Avion. I also think you will like the Hensley. With the Hensley and the Avion lower center of gravity, I bet you'll find the rig driving stability is better than your 5th wheel was.
If you need any advice on installing the Hensley, let me know. I've installed mine on 3 different trailers. I finally gave up on the orange paint and painted everything black.
Old Mar 30, 2012 | 12:36 AM
timf150's Avatar
timf150
Rear Blocks
Looks good....
Did you use your original rear block with the B-codes?
I have a dilema in that I don't have the original rear block so I am not sure what most people have as stock. I picked up two blocks one it about 1 7/8 inch and the other is a tapered block that is about 2 1/4 to 2 3/8. Not sure which one is right to use with my moded b-codes.
Tim M
Old Mar 30, 2012 | 01:50 AM
9905's Avatar
9905
Since I was using the RAS and modded the Bs I used the factory blocks. If you mod the Bs and use the F350 blocks your rear will be even higher.
Old Mar 30, 2012 | 07:19 AM
Snowseeker's Avatar
Snowseeker
Originally Posted by jayjjcc
Off topic, don't want to hijack, but is snowseeker a welder
Yeah I weld stuff, machine stuff, fix stuff, solder stuff, paint stuff, and sometimes break stuff.
Old Mar 30, 2012 | 09:13 AM
HeathJohnson's Avatar
HeathJohnson
I'm good a breaking stuff...
Old Mar 30, 2012 | 09:37 AM
timf150's Avatar
timf150
9905,
Neither of my blocks are the F350 tapered blocks that are about 3.75 inches high.
Was your stock rear block square or was it tapered?
Tim M
Old Mar 30, 2012 | 10:41 PM
9905's Avatar
9905
Originally Posted by timf150
9905,
Tim M
To be truthfull, I am not 100% sure. I know they had an arrow that pointed to front. So I am 99% postive they had some taper but they were not the big ones from an F350.
9905
Old Mar 30, 2012 | 10:47 PM
9905's Avatar
9905
On a side note, I did mod my B's because I do tow a lot. I have been suprised how much the rear settles with the mod B's and the RAS. Not sagging in the rear but level.
So I would recommend to anyone that ever plans on towing even once in a while going the coughing up the cash and going the mod B route instead of factory stuff with the F350 blocks.
The trailers I tow are car trailer and a dump trailer not weight distribution set ups. Each trailer is normally filled with firewood, a B series kubota, or a bobcat. I also tow my Avion which has around 1000 pound tongue weight when fully loaded.
9905
Old Mar 31, 2012 | 07:31 AM
9905's Avatar
9905
Forest, thanks for the help yesterday. I got you some reps sent now.
To the Forum in general. Good class of guys willing to help out. Thanks.
Oldguyfl
Jul 22, 2016 07:27 AM
Drunken_Unicorn
Mar 20, 2015 06:00 PM
Redeyeracing
Sep 30, 2011 10:04 PM
gr8scott72
Sep 24, 2009 06:21 PM
RichCT
Apr 16, 2003 03:16 PM
