Chevy 267 starter replacement
Old 02-15-2015, 05:11 PM
RJNRJN's Avatar
RJNRJN
RJNRJN is offline
I'm a newby and I'm stuck. I have a '52 F1 with a 1980-ish Chevy 267 small block and Chevy transmission. The starter was clicking 20 or 30 times before the engine would fire up. I replaced the battery which did not help.
So, I bought a replacement starter. Advance Auto parts said I needed a Tough1one P3502S, so I put that in.
The wiring is the problem. I wired it the same as the old one: On the solenoid: battery cable and a heavy gauge red wire and a lighter gauge black wire to the big main terminal, no wires to the 2 small terminals below the main. Then a small black wire the back of the starter where there is 1 small terminal.
Nothing happens when I turn the key. I tried moving wires on the solenoid to several combinations on the three posts, always leaving the battery cable on the large post. Nothing worked.
Anybody know what to do? Now I'm not sure if this even the right starter.
Thanks in advance.
BostiPB
1978 - 1996 Big Bronco
05-25-2011 09:29 PM
brian8you
09-14-2010 08:13 PM
Ryokotsusai
10-13-2006 11:47 PM
david00f150
06-06-2006 04:16 PM
cjf5150
31
03-17-2006 05:47 PM
Quick Reply: Chevy 267 starter replacement
