No way without a heatplate manifold for Offy DP
I want some of what those folks at Raso are smoking. I had a local welder fab up a plate for me out of a piece of 1/4" aluminum and a couple of heater elbows I got from a local rod shop. Total cost was $30.
Never used a carb heat plate, but I'm in Texas and don't have to worry about the carb icing. Even in summer the manifold heat helps.
Theoretically, but it would involve me driving out to the shop where I got the elbows then over to the welder who fabbed it up and I won't be able to take any time off at the office any time soon. IMO, it's the elbows that make it such a tidy piece. You can get them from Sachse Rod Shop here:
Sachse Rod Shop
Any competent welding shop should be able to cut a base plate from some 1/4" aluminum plate and TIG weld everything together.
Sachse Rod Shop
on the subject of heat plates
I was looking at the underside chamber on my Offy 'C' manifold.
The pocket extends a ways into a 'hidden' double wall cavity around the threaded hole's casting boss. I'm pretty sure the cavity goes around the bolt boss all the way.
I thought to promote better circulation and heat transfer of the water, the heat plate should have a divider fin welded on it, like a plenum divider in a V8 manifold. That would force the water around the long way, instead of flowing directly from one inlet pipe and out the other.
The fittings would have to be on opposite sides of the divider fin of course.
O >
-----bolt
O <
-----bolt
O <
O >
-----bolt
O <
-----bolt
O <
I'm pretty sure a dividing fin won't be necessary as well. As long as the fittings aren't right next to each other, there should be sufficient flow to heat everything as desired. I believe the fin would add an unncessary complexity to the design as it would have to seal against the bottom of the manifold to do any good. If the area were larger, I could see the use of a dividing fin.
coolguy1419
42
09-14-2014 07:32 AM
