6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Driveline Vibration
Old Mar 27, 2012 | 03:50 PM
chi6488's Avatar
chi6488
Driveline Vibration
I have noticed that my rear end is bouncing quite a bit. I have worked my tire guys to death. They have done the road force balancing and even spun the tire to get it right which I never saw ford dealer do. Swapping tires from front to rear didn't help either.
The rear end bounce comes and goes, hot or cold tires, foot on the pedal or not.
I called like a truck shop and he said that it is due to springs being really stiff and all heavy duty does it and can't explain why. Some trucks do it and some don't.
First step I am trying to rule out is possible rear u joint bad? 47k miles. I have not towed in a very long time but it used to do it when back then. With a good load it would not bounce.
I have michelin ltx ms2 tires so I dooubt they are tires. Basic size tires.
Any suggestions?
Old Mar 27, 2012 | 05:25 PM
R-T0r21on's Avatar
R-T0r21on
If the U-joint is good, check for something bent, such as the drive shaft. carrier bearing may be mseed up, but probably not the issue. Rims are in good shape (not bent)? Reduce rear tire air pressure to about 50 psi. You may want to lube the splined end of your drive shaft. Drop the end at the tranny, pull it apart, lube it up good, re-install. Good luck with that. I hope this helps you
cnd150
1983 - 2012 Ranger & B-Series
Feb 2, 2007 10:09 PM
Sicko
16
Jan 6, 2005 07:11 PM
MoEx
Jan 9, 2004 02:35 PM
jpatter
Dec 17, 2003 03:10 PM
Drexx
Feb 5, 2003 06:35 AM
