Help
Old Mar 27, 2012 | 02:44 PM
Chewee's Avatar
Chewee
Help
Ok I just bought a 73 F250 when I bought it it started right up and ran ok. The guy told me that it needed to be timed. Haven't timed it yet but when I got it home it would die when I would put it into reverse and in drive. So I park it and the next day I started it up and took it for a spin to warm it up when I got back same thing. What is the problem I'm about to take it to mechanic but if it's something I can do myself to save some money I will. It has a 460 automatic Trans. Some ideas would be great.
Old Mar 27, 2012 | 02:51 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check for vacuum leaks and also check the idle speed and carb adjustments.
Welcome to FTE. Lots of good, knowledgeable people here.
Old Mar 27, 2012 | 03:13 PM
crazy96863's Avatar
crazy96863
You have a great vehicle to learn about being your own mechanic. Before you know it, as you fix things on your own you will be a bit of an expert in that area. Otherwise your mechanic is going to become your best friends as there is always something to fix on these trucks... It can be really cheap or really expensive. Your choice.
Old Mar 27, 2012 | 05:11 PM
Chewee's Avatar
Chewee
What is the best way to check for a vac leak. Also where is the best place to get info on how to set the timing, adjust the carb?
Old Mar 27, 2012 | 05:14 PM
crazy96863's Avatar
crazy96863
Listen for the hiss while its idling... Check all the obvious stuff like your hoses; make sure their not busted or disconnected.
Internet... You would be surprised at what you can youtube also. I bet someone has posted about it here; check the engines section.
Old Mar 27, 2012 | 05:58 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Also, get a can of WD-40 or similar. Start by spraying around the base of the carb., along the edges of the intake manifold then along any vacuum lines. If there is a vacuum leak you'll notice a change in the idle.
Another thing you might check is the vacuum advance on the distributor. Very common for them to go bad and leak.
Old Mar 27, 2012 | 06:55 PM
Chewee's Avatar
Chewee
But could it be the timing as well?
PapaBearYuma
Mar 1, 2017 12:31 PM
SWD75
Aug 7, 2016 07:43 AM
DikHedECV3
Nov 30, 2012 02:22 PM
kingcustom04
17
Dec 29, 2009 04:56 PM
olthunter
Jul 17, 2001 06:22 AM
