1978 - 1996 Big Bronco
transmission change
Old Mar 27, 2012 | 09:03 AM
revans9295's Avatar
revans9295
transmission change
i have a 1987 FS bronco 4x4 with a 5.0 and a C6 tranny . what 4-speed automatic transmission if any can i put in this for better fuel economy . looking for one that i can take the old one out and put new one in without alot of issues . thanks
Old Mar 27, 2012 | 11:06 AM
85e150's Avatar
85e150
A beefed AOD, not inexpensive.
AOD StreetFighter® Transmission 4X4 - TCI® Auto
serving suggestion, ymmv.
Old Mar 28, 2012 | 09:33 PM
greystreak92's Avatar
greystreak92
You will need the TV (throttle valve) cable setup to run an AOD. It can be done (it was a factory optional slush-box) but it will not function without this.
Old Mar 28, 2012 | 09:40 PM
revans9295's Avatar
revans9295
Is the AOD a good choice to change to ? And all I need is the tranny and TV cable ?right. No computer stuff ?
Old Mar 28, 2012 | 10:54 PM
Encho's Avatar
Encho
The Southernmost Mod
No computer with the AOD.
Old Mar 28, 2012 | 11:31 PM
85e150's Avatar
85e150
What gears do you have?
One thing you have to watch is too tall an OD. If you have 3.55s and 31 inch tires, that 302 isn't going to pull OD on any little bit of an incline, and barely on the flat under 65 mph I'd guess.
If you have 4.10s or more, it might work ok.
Do some math on your annual miles driven, current mpg vs. projected mpg--heck, be generous and increase your mpg 20%. See if this will ever pay off.
Old Mar 29, 2012 | 02:41 AM
greystreak92
OEM axle gearing in the Bronco with OD transmissions was still 3.55:1 (unless you have a 300 under the hood, then its 3.08:1 stock) The OD gear in the AOD is 0.67:1 The 302 pulls just fine with stock tire sizes LT235/75R15/C - 31x10.50R15/C (between 29" and 30.7" ACTUAL inflated diameter) and OD. Get much bigger and things start to go south quickly. Its worse with the E4OD which relies on engine and axle rpm's to calculate shift points. You wouldn't want the headache of an E4OD anyway... it NEEDS the computer.
I would tend to agree though that it seems a hefty undertaking for something that would most likely yield only marginal changes in MPG. Save fuel by adding propane injection or dropping engine sizes. The 302 rev's its little heads off pulling a full-size Bronco around anyway.
Old Mar 29, 2012 | 09:09 PM
revans9295's Avatar
revans9295
I have 3.55 gears , with a 302. Would it be better to put a 351w in it ? Or what engine for better mileage ?
dlong950
Sep 4, 2010 09:47 AM
84ford150
Apr 12, 2008 02:38 PM
Kraig84F150KingCab
Mar 15, 2008 07:12 PM
RUCrazy
Jun 21, 2006 02:13 PM
gov2mod
Sep 26, 2005 12:11 AM
