Obligatory newbie thread
Old Mar 27, 2012 | 04:56 PM
owlcore's Avatar
owlcore
Love the Quantums, rare old birds now! i actually sold a 93 Fox to buy this truck, and I still have a 67 Bus and 73 Beetle in the stable too.
Old Mar 27, 2012 | 09:51 PM
lafermedavid's Avatar
lafermedavid
regrets
I had a 64 bug mint should of never got rid of it,i had a 77 F 100 should have never got rid of it{my first ride}.i now have a 75 HB im not getting rid of it
Old Mar 27, 2012 | 10:16 PM
79_effie's Avatar
79_effie
Originally Posted by lafermedavid
nice find,I like my dubs too 1984 1.6l D Quatum SW mint
Had to grin when I saw this. Remember when "dub" only meant a German car and not rims?
Old Mar 28, 2012 | 07:00 AM
owlcore's Avatar
owlcore
Haha yes, the good old days!
I'm so excited, the truck hopefully comes home today!
Old Mar 31, 2012 | 07:52 PM
owlcore's Avatar
owlcore
SUCCESS!!! Well, sort of... I fixed one problem and created another... The truck wasn't running because there was some rubber debris in the float needle, which I cleaned out. Now it starts and idles, but it's spraying fuel out of the balance tube that runs between the float bowls. Hopefully it's just a matter of replacing the O-rings and it'll be good to go! Unfortunately I ran out of daylight and it's too big to fit in my garage. Tomorrow!
Old May 11, 2012 | 03:19 PM
owlcore's Avatar
owlcore
Allright time for an update... it is on the road! Got a new Edelbrock carb for it after fighting the Holley only to have it still leak. Changed the plugs and the oil, tightened up the loose bits, and it seems to be happy! I took it for it's maiden beer run yesterday. What a blast to drive!
There are a couple little issues I've noticed so far. Firstly, it has an automatic transmission, but it won't start if it's in park or neutral, like it's supposed to. You have to put it in reverse to get it to go, which is less than ideal. I'm assuming that the switch that controls this just needs to be adjusted so it lines up in the right shifter position. Where is the switch located?
Also, the fuel gauge doesn't work. It has the two tanks under the bed, and I'm just using the front one. What are the common causes for the gauge not working? I'd really like to have that going, this thing is a little heavy to push out of the road if it conks out, haha.
Other than that it's been so far so good, I'm really loving this truck!
Old May 11, 2012 | 04:03 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The nuetral safety switch (NSS as many call it) is located on the side of the trans, where the linkage attaches.
Old May 12, 2012 | 03:37 PM
owlcore's Avatar
owlcore
Great thanks! I'll try to climb under there today.
Also this is a dumb question, but why are these trucks referred to as dents?
Old May 12, 2012 | 04:39 PM
Rogue_Wulff
The depression along the side, where the trim sits is reffered to the "Dent", thus 73-79's are called dentsides.
67-72 trucks have a raised "bump" in nearly the same location, and are refered to as "Bumpsides".
People shorten those up to just "Bumps" and "Dents"......
Old May 13, 2012 | 06:28 AM
mikeo0o0o0's Avatar
mikeo0o0o0
That's for 78-79. The NSS for '73-77 is located on the steering column, under the dash, near the firewall. There are two screws that attach it to the column. Loosen the screws and you can move the switch to adjust.
This switch also controls your back-up lights.
Old May 13, 2012 | 10:50 AM
Rogue_Wulff
Ya know, I knew that, just got the years confused. Easy to do, when you have both types..... The trans mounted switch also applies to 80+
I even remember having to unhook the wires from the NSS when I removed the column of the 74, and thinking I needed to make a note of that.
Old May 15, 2012 | 07:27 PM
owlcore's Avatar
owlcore
Alright so I found the neutral saftey switch, it was on the column near the pedals. I tried to adjust it per the instructions in my Haynes manual, but it still doesn't work. Actually after I followed those instructions it wouldn't start at all in any gear. After some more fiddling I got it to the point it would start in reverse again, which was the case when I got the truck. Obviously I screwed up in following the Haynes procedure, so does anyone have an easier to follow tutorial? Or is there a way to just bypass the damn thing? It seems pretty pointless and I'd just as soon not have to worry about it. I don't foresee anyone dumb enough to actually need this "safety feature" ever driving my truck, and either way that would be a lot safer than having to start it with it in reverse!
Matt Js 54
Aug 18, 2019 10:13 PM
Mjensen717
Jun 22, 2018 10:24 AM
littlegram
22
Sep 14, 2017 09:18 AM
jrosso
May 4, 2017 01:33 PM
1980 Ford F-250
24
Feb 1, 2012 10:47 PM
