I have an 05 f350 with the 6.0 , and I have been having a lack of power sometimes, usually after driving truck up to normal temp, . I had the dealer run a scan on it and they said the EBP SENSOR was bad and they had to replace that first before determining if the unison ring was stuck, they said this may just be the problem, or may not be. Any truth to this? Does the EBP control how much the vanes are suposed to open or close?
They also said there were several codes, they were , P0069, P0470, P0470, P0471, P0478,
On the report they said EBP sensor bias connector falling apart. Needs sensor and connector. When I looked at the sensor it looked fine to me and the connector pluged and unpluged fine, do you think I should replace it(connector) ? Or do they self destruct in a way you cant see?
THANK YOU FOR ANY HELP YOU CAN PROVIDE ME WITH!
