2004 6.0 advice needed
Old Apr 13, 2012 | 10:34 AM
BLADE35's Avatar
BLADE35
try and get codes scanned
Then pull egr valve see if its stuck open or any sign of coolant in there
Also if it wont do a cyclinder balance test for injectors another option is to Pull the fuse for fuel pump and FICM fuse
then pull cover off upper fuel bowel and watch for bubbles as someone cranks over the starter
if it has bubbles theres either a Bad Injector or cracked head not to common this last one
Old Apr 13, 2012 | 01:10 PM
bohrer54's Avatar
bohrer54
Great tip on the injector, that makes complete sense now that you say it. when i can i will check everything out and report back.
Thanks again
jnobles06
Aug 25, 2018 04:19 PM
Per4mance
Oct 13, 2013 06:31 PM
VCEC71
Oct 27, 2010 07:25 PM
HP junkie
General Automotive Discussion
Jan 9, 2008 07:57 AM
FordF350FX4
Jan 31, 2006 09:16 PM
