keyless entry codes
Old Oct 10, 2013 | 07:30 AM
Per4mance's Avatar
Per4mance
keyless entry codes
I finally got my remote key fobs working (that's another story ) and I want to see if I can get the codes off the modual in the truck, hopefully the PO didn't change them because I'll have to go to Ford. Being a GM guy I have no idea even where the modual is but read somewhere the code is on it. Any one have a clue, I looked in the stickies but no luck.........Bill
Old Oct 10, 2013 | 09:09 AM
Bruce Thompson's Avatar
Bruce Thompson
The easy way to local this module is by taking the auxillary ashtray out ( small panel with tab for hanging stuff). Once you have it out, you will need to use a flash light and look for a small black box with three connectors ( grey, green, blue ) plugged into this box. There should be a white label with black print. In the corner of that label should contain 5 numbers. Enter that code and it should work.
Old Oct 10, 2013 | 09:55 AM
Rusty Axlerod's Avatar
Rusty Axlerod
The personal code a previous owner may have programmed is in addition to the original code. The factory code remains in memory.
Old Oct 10, 2013 | 10:50 AM
99ExpyProblems's Avatar
99ExpyProblems
There is a way to reprogram the code too, once you find the factory code.
When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
To create your own personal entry code:
1. Enter the factory set code. The driver door will unlock.
2. Within five seconds press the 1 • 2 on the keypad.
3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
4. The doors will lock then unlock to confirm that your personal keycode has been programmed into the module.
Old Oct 10, 2013 | 06:32 PM
Per4mance's Avatar
Per4mance
ok, good deal going to try it later this weekend
Old Oct 10, 2013 | 06:56 PM
05F250DSL's Avatar
05F250DSL
I tried and tried and finally had to pull my radio out move the insulation then reach in with my phone and take a pic. I just could not see it past the insulation. It did not take ten min. To pull out the radio and get it.
Old Oct 10, 2013 | 07:36 PM
Yahiko's Avatar
Yahiko
You may run into a problem with the newer trucks.
The word is that Ford quit putting that little label on
the unit, So that leaves you with going to someone
that can read it with a computer.
Sean
Old Oct 10, 2013 | 07:39 PM
Per4mance's Avatar
Per4mance
Ya think my modis can read it ? It's all up to date, it would be a hell of a lot easier too
Old Oct 10, 2013 | 08:02 PM
99ExpyProblems
Old Oct 10, 2013 | 08:13 PM
big inch's Avatar
big inch
By far the easiest way of getting the code is with an ids if you know anybody with access to one.
I don't suppose the code card is still with the owner's manual? It is a credit card sized white card that has the factory code on it.
Old Oct 10, 2013 | 08:20 PM
Per4mance's Avatar
Per4mance
Nope, when I got the truck all it had was 1 key and that was it. I've had to get everthing else the hard way, and belive me the wheel locks sucked big time LOL
Old Oct 10, 2013 | 08:24 PM
Rusty Axlerod
How about the key for the spare tire lift ?
I drove my truck for months before I realized I couldn't drop the spare if I needed to
Old Oct 10, 2013 | 08:28 PM
Per4mance's Avatar
Per4mance
Nope, don't have that yet either lol
Old Oct 10, 2013 | 08:55 PM
05F250DSL's Avatar
05F250DSL
Wait there's a different key for the spare tire?? Crap I guess I need to check mine I never checked.
Old Oct 10, 2013 | 08:56 PM
Yahiko's Avatar
Yahiko
I did have mine. But my local dealer that I did not get the truck from said if I did not have
it that they would just go to the repair dept and barrow the master set and find the
right one for me and order it.
I find it helps to have a good relationship with your parts people.
I got lucky on the code and my card was in the owners guide that came with
a used truck. That was a nice surprise.
On the tag on the module I think it was 06 or 07 that they quit putting it on.
If you have a video bore scope that would be the easy way to look for it.
Sean
