Bucking when going slow
Old Mar 26, 2012 | 01:49 PM
jack_pine's Avatar
jack_pine
Have just about 1,600 miles on tuck born on 12/14/11. Love it, but..
When going slow in subdivision I am getting some hesitation/bucking when going in the upper 20s/lower 30s. When I feel it I look down and I am usually in 3rd.
Is this the transmissible thing? When it happened Sunday it felt like it was going to die. If I start off with a quicker start (to get to highway speed) it shifts fine.
Any thoughts? It just started the last few weekends......
Old Mar 26, 2012 | 02:11 PM
darren32's Avatar
darren32
Mine has always been like that....
When driving (almost any speed):
-If I roll on the throttle;instead of down shifting it just bucks like crazy and makes a slapping sound from the trans.
-If I get hard on the throttle it down shifts a couple of gears and takes off like a rocket.
No in between.
BUT, I am lacking a transmission TSB that replaces some solenoids etc...so maybe it's just me.
Thanks
Old Mar 26, 2012 | 02:12 PM
jack_pine's Avatar
jack_pine
With my build date of 12/14/11 I should be up to date with all that stuff?
Old Mar 26, 2012 | 02:32 PM
darren32's Avatar
darren32
Yes, I believe the TSB is only for Job 1 2011's so you should be good to go.
IMHO, (and likely in the name of fuel economy) the trans is always in at least one or 2 gears too high for driving around town / driving slow. I believe that is why mine alwasy feels sluggish and bucks when driving slow.
To test my theory, try driving in T/H, it should go away. But then you are stuck with those nasty hard down shift that smack your forehead into the windshield
Thanks
Old Mar 26, 2012 | 02:39 PM
jack_pine's Avatar
jack_pine
I'll give that a shot. Problem is it does not seem to do it every time and not sure if I can reproduce it at will for the dealer................
Old Mar 26, 2012 | 02:43 PM
darren32's Avatar
darren32
I think that's why you can't reproduce it at will....becuase it depends on what gear you are in at what speed, at what RPM AND how much you push the go pedal down. Keep practicing
Old Mar 26, 2012 | 07:31 PM
jack_pine's Avatar
jack_pine
Really, only Darren?
When this happens and you press the pedal it stutters. I am not sure it is a transmission issue or something else. When it comes out of it it drives fine. It's only on slow accelerations to a slow spped (like in a 30 mph zone)
Guess I should stay out of those.
I am tempted to ask the dealer to reset the adaptive learning thing. Will they do that by just me asking?
Old Mar 26, 2012 | 07:52 PM
los341's Avatar
los341
For what it's worth, I have never experienced the hesitation thing. The pedal feels smooth and the engine has a full range of acceleration and rpm. There is nothing "touchy" about the accelerator.
Old Mar 26, 2012 | 07:59 PM
jack_pine's Avatar
jack_pine
How many miles?
One other note, I smell the burnt smell when I got out so I think it was doing a regen. Don't know if that was a factor or not..................
Old Mar 26, 2012 | 08:09 PM
los341's Avatar
los341
How many miles?
2400 miles. No hesitation, no bucking, no 49mph death wobble, HPFP works great. I can't complain!
Old Mar 26, 2012 | 08:41 PM
garbenn's Avatar
garbenn
Mine does the same. Usually durring the first time in the morning i'm leaving the driveway under slow acceleration, seems to be an engine issue. After the first mile it seems to disappear. Stopped at the dealer to check if there was any issues being brought up by owners or ary recalls or service bulletins. They check while I watched and the service manger couldn't find anything. SO, if anyone comes up with any information on this annoying problem, please let me know. O ya. 18000 miles on it.
Old Mar 26, 2012 | 10:12 PM
stro1965's Avatar
stro1965
Mine too, I think it's just cold blooded, clears up within a mile.
Old Mar 27, 2012 | 08:14 AM
6.7Fan's Avatar
6.7Fan
You can reset the learning process yourself by disconnecting the batteries. I did it once last year. I disconnected both batteries overnight (wasn't sure how long it took). No issues at all from doing it. My shifting did seem much better for a while, then it went back to rough shifting. A couple of months later the TSB came out and I had that done. It's been, for the most part, great since then.
Old Mar 27, 2012 | 01:40 PM
2ndStroke's Avatar
2ndStroke
Driving slower in town or when the engine is cold and I take it easy on it, my truck does the same thing, hard shifts, seems like the truck isn't sure of what gear to be in. Even coming into town slowing down 6th to 5th it shifts really werid and the shudders. When I drive it harder it seems to shift way better. My truck also does the horrible shifts from 2nd to 3rd, seems worse when its cold.
Old Mar 27, 2012 | 08:33 PM
garbenn's Avatar
garbenn
The problem I'm incountering is not transmitiom shift, but a stutter under slow acceleration like the engine is miss-firing
