Electrical Issues/Starting Problems
Old Mar 26, 2012 | 12:43 PM
Vaokie1's Avatar
Vaokie1
Been having issues for a couple of months with my 78 F100 302/C6 2wd pickup. I have replaced the following items: battery, voltage regulator, coil, alternator, starter solenoid. The last time I got it started I let it run for 30 mins and then shut it off. Since that day I haven't been able to get it started. It will crank, sometimes slow, other times normal, it will sputter some but never fire. I have been noticing that the battery cables and starter cables are getting smoking hot after cranking the motor a short time, yesterday the ignition switch hung and it kept cranking until I wiggled the key. Any clues on what my problem may be? Thanks for the help
Old Mar 26, 2012 | 05:03 PM
Vaokie1's Avatar
Vaokie1
Got home and tried to start it again cranked it a couple of times heard a noise under the hood, checked on that and found my. Negative/ground cable had melted off the batt post. Is my problem in the starter or ignition?
Old Mar 26, 2012 | 05:14 PM
bertha66's Avatar
bertha66
You may have a dead short in the starter. Pull the starter and have it tested. The ignition timing being off can cause the same problems, making it pull a lot of voltage to try and start the engine. It will also over heat the battery cables.
Old Mar 26, 2012 | 06:57 PM
Vaokie1's Avatar
Vaokie1
Can you give me a reason why or how the starter can get a dead short?
Old Mar 26, 2012 | 07:49 PM
bertha66's Avatar
bertha66
How old is the starter, your post did not say you replaced it. When they get old and the the bearings can wear down and the armature will set down against the field. Armature winding's go bad. Bad brushes.
Old Mar 26, 2012 | 07:56 PM
Vaokie1's Avatar
Vaokie1
To be honest I do not know how old the starter is, I had a Jasper engine put in it 3 years ago and do not know if this starter if from the original motor (my guess is that it is, so it would be 1978 with 70,000 miles on it
Old Mar 26, 2012 | 09:04 PM
bertha66's Avatar
bertha66
I would pull it and have it checked. Most auto parts stores will test for free.
carnagez28
Aug 25, 2006 08:10 AM
dcdave
20
Dec 20, 2005 01:49 PM
d9h
1966 - 1977 Early Broncos
Nov 6, 2003 07:59 AM
neednewranger
1983 - 2012 Ranger & B-Series
19
Jul 20, 2003 10:55 PM
Zukster
1978 - 1996 Big Bronco
Jun 19, 2003 06:37 AM
