Anyone install a aftermarket fuel filter set up yet on a 2011 or 12? Got a truck on order and I plan on putting a transfer flow setup in the bed but I want to filter the fuel prior to going into the main fuel (stock) tank. Kinda new to the PSD world, any advice would be apreciated.
1.RDS 60 gallon tank
2.Wix 24309 filter base
3.Wix 33123 fuel filter/water separator
4.Airtex fuel pump
5.12 v. fuel shutoff valve
6.Autometer fuel gauge mounted on dash
Items 2-5 all mounted to heavy aluminum plate then mounted to outside of the left frame member. The fuel is delivered then to aft 40 gallon stock tank. The fuel shutoff and fuel pump are connected to upfitter switch #3.
My truck is a chassis cab with aluminum flatbed.
I used similar setup on the 04 F250 SRW pickup.
