E4od vs Aod starter
Old Mar 25, 2012 | 09:56 AM
t_hess66's Avatar
t_hess66
E4od vs Aod starter
I am swapping out my e4od for an aod in my 92 F150 with a 302, and i am wondering if i will be able to use the same starter? Thanks
Old Mar 25, 2012 | 10:50 AM
jroehl's Avatar
jroehl
The bellhousings are the same, and the starter engages the flexplate, which is not part of the transmission, so there's no difference.
I wonder why the downgrade in tranny, though? If you do go through with it, make sure that you get the TV cable properly set up, or you'll toast that AOD in no time.
Jason
Old Mar 25, 2012 | 12:35 PM
t_hess66's Avatar
t_hess66
Well its not really a downgrade, im putting a carb on the truck and the aod i have has been rebuilt with a shift kit, different valve body, and a 2400 stall converter to go with it.
Holehawgg
21
May 27, 2012 10:34 AM
92fatford
Feb 17, 2008 08:08 AM
EgoMan
Jun 24, 2006 01:33 AM
turboguy
Mar 13, 2005 04:36 PM
threefiftyone
Apr 24, 2004 12:21 AM
