T5 Adaptors
Old Mar 26, 2012 | 07:08 PM
Damifiknow's Avatar
Damifiknow
Originally Posted by Rj Williamson
would a t5 from a mustang work with this adapter too
Yes but shifter is too far back. It would come out under the seat.
Old Mar 26, 2012 | 07:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Actually, I think the Ford T5 bolt pattern is different than the S-10. If the adaptor accomodates both patterns, then yeah, they'll work.
Old Mar 26, 2012 | 08:24 PM
vintage tin's Avatar
vintage tin
sorry if this is to long,but i haven't being fallowing along on this one.
first.jmadsen.
where did you get that plate or should i say when,last i heard Dwight Bond was nowhere to be found so say the guys on the H.A.M.B.IIRC that adapter will fit the mustang and the s-10 t5.
Ross
yes and no.Speedway has them for stock or hydraulic .
Damifiknow.
all you need to do is get a driveshaft from a c4 or c6 that is to long and have it shortened,they use the same slip yoke as the t5.
RJ Williamson.
again,Speedway has them for both the s10 and the mustang.
the biggest problem i had with this swap was i had to clean the casting slag off the 3 counter weights on the pressure plate,they were rubbing on the adapter housing at the bottom,just grid off the little ridge and everything works pretty good.
Old Mar 26, 2012 | 10:12 PM
oldmerc's Avatar
oldmerc
oldmerc
Vintage Tin
What pressure plate did you use ?
Old Mar 27, 2012 | 04:17 AM
vintage tin
i had the stock one resurfaced.
Old Mar 27, 2012 | 07:33 AM
oldmerc's Avatar
oldmerc
oldmerc
Just to confirm , did you used the stock 11 inch pressure plate ? Reason I ask is because the instructions say that it won't work .
Old Mar 27, 2012 | 05:04 PM
jmadsen's Avatar
jmadsen
Originally Posted by havi
Josh, that looks good!
Any chance you could measure the center to center bolt spacing where the tranny meets the bell? Top to bottom, both sides, side to side for both in case they are aren't a perfect square, and diagonally to each other. I've got the Ford pattern, but i don't have the S10/GM pattern, and i'm looking at this option for an OT pickup. It appears find a 2wd t5 is difficult up here in 4x4 country. Thanks
Or if anyone can point me to a site or thread showing it, i don't want to be too much trouble.
I have yet to complete the install but have the adapter bolted to the trans and half bell buried in the corner of the garage. if I can clean shop enough to find it I'll check measurment s.
to others yes I had heard on different threads over on the hamb that as well but I think he's still around?? keep trying. I think he had a new # maybe and that he was sold out of them but if he had an order of 10 of them he would make more??
My stock F-1 crossmember was already cut out by po but it's just a narrow portion of the center of memeber so I still have the brake and clutch pedal MC assembly etc.
Old Mar 27, 2012 | 09:02 PM
vintage tin
sorry oldmerc,yes i used the stock pressure plate and flywheel.
they are both for the 11 inch clutch,the disc i used is 9 1/8 14 spline 1 inch shaft for a 86 s-10 5 speed.i got it from Napa in Lethbridge,part # RC4203 $79.00.
the 9 1/8 disc is plenty big enough for the power of the flathead under normal use.
tndallas
19
Jul 17, 2021 07:33 PM
imradlol
Feb 22, 2019 01:49 AM
RattyFord
Feb 15, 2019 10:45 AM
Tomc750
Large Truck
Sep 6, 2018 06:29 AM
chappys4life
15
Dec 1, 2011 03:42 PM
