Hello there, my 92 F150 4x4 needs new radius arm bushings. Mine have ~1" of play in them. I ordered the new ones already. I have A 4" lift so the brackets have already been switched over to bolts. My question is do I need to jack The truck up to remove the brackets? If not what is the proper way? Ford wants $475 plus parts to do it and thats just WAY too much... Please help
I throw a jack stand under the frame at work to take all the tension off the radius arm and make it way easier in my opinion to work with. Plus use some wd-40 or pb blaster, magic stuff on bolts.
