quick need help please
Old Mar 24, 2012 | 12:30 PM
powerstroker100's Avatar
powerstroker100
Currently replacing my ps pump again
The pump from ford came with two seals
1 rubber o ring and 1 teflon I have no idea where they go?
Someone please comment were in the middle of moving and I need my truck running
Thanks!
Old Mar 24, 2012 | 02:46 PM
Rusty Axlerod's Avatar
Rusty Axlerod
On the end of the pressure and return lines where they go in the pump maybe?
Old Mar 24, 2012 | 03:38 PM
mhoefer's Avatar
mhoefer
That would be my guess too. Where pressure and return go into pump. Unbolt pump from bracket, move out of way with hoses on, hold upright. Maybe even suck out ps fluid before. Then bolt in place new pump. Transfer return hose, transfer pressure hose with appropriate seal replacement, remove old pump. Fill with fresh fluid, run pump, cycle steering, pull out fluid from reservoir and refill with fresh. Test. I would put front axle on jack stands so you can cycle steering in shop. Make sure you block rear wheels, park, with brake on hard. Safety first.
Old Mar 24, 2012 | 06:31 PM
69cj's Avatar
69cj
When your done and everything is working properly install a Magnefine #R038M filter in the return line.
Old Mar 25, 2012 | 06:56 PM
powerstroker100
Hey guys I've had the pump in for a day now and it works great my steering is back and my brakes are back, but its leaking out of the fitting where the high pressure line screws into the pump, so currently I have no seal on
Can someone help??
Old Mar 25, 2012 | 11:02 PM
critterf1's Avatar
critterf1
IIRC that should be where the little white plastic seal belongs.
Old Mar 26, 2012 | 12:41 PM
powerstroker100
That's what I thought aswell, but I fiddled with it for 30 minutes after I mounted the pump under the truck and couldn't figure out how it fit in there, its a smaller diameter than the high pressure line fitting so I couldn't thread it in with that white teflon seal there
Any other ideas guys?
wotan
May 15, 2018 09:51 AM
Island Time
Dec 15, 2014 02:49 PM
sibernut
Aug 14, 2012 02:31 PM
rubber_city_cowboy
May 26, 2012 08:42 PM
Cudighi
Sep 24, 2003 03:09 PM
