I started
Old Mar 23, 2012 | 11:28 PM
Vinford's Avatar
Vinford
I started
I started a thread here a couple of weeks ago about a 88 F-250 I couldnt get running.
I cant find it anywhere which is strange?
A couple of guys told me to switch out the computer which I did.
Still doesnt start.
Old Mar 24, 2012 | 06:55 AM
Scndsin's Avatar
Scndsin
In your user CP, clicking on "view all subscribed threads" doesn't show it? Then only a mod could have deleted it.
Old Mar 24, 2012 | 07:20 AM
cjben's Avatar
cjben
wow,that's weird. I looked at all your posts clear back to mid January and didn't find any that had to do with a truck not starting.
Old Mar 24, 2012 | 03:42 PM
deljac's Avatar
deljac
whats it doing when you try starting it and what have you tried on it so far
Old Mar 24, 2012 | 06:45 PM
Vinford's Avatar
Vinford
It starts right up when you pour gas in the throttle body.
It will keep running if you pump the gas pedal but as soon as you stop pumping it quits.
Fuel filters have been changed and I tryed a diffrent computer in it.
As far as that other thread it was called "Reset" and I cant find it.
Thats really strange.
Old Mar 24, 2012 | 10:39 PM
Vinford's Avatar
Vinford
Well Ive looked at every thread in this forum and I cant find my thread on where the fuel reset is?
Somethings funny , there was nothing in that thread to make it deletable?
This is the only Ford specific forum I go to so it wasnt somewhere else.
I had a couple of guys tell me where the reset button was.
Old Mar 25, 2012 | 08:52 AM
tjc transport's Avatar
tjc transport
i ain't rite
ok, lets start over again. you have an 88 F250 that will only run if you pour gas in the thottle body.
what engine, and what have you done to it so far?
Old Mar 25, 2012 | 10:20 AM
Vinford's Avatar
Vinford
Its a 88 with a 460.
Changed fuel filters.
Changed computer.
Starts right up by pouring gas in it and will keep running if you pump the gas pedal.
Quit pumping and it quits.
Old Mar 25, 2012 | 01:51 PM
tjc transport
i ain't rite
have you checked fuel pressure at the regulator or fuel rail?
it may be something as simple as a corroded connection on the fuel pump relay.
Old Mar 25, 2012 | 03:52 PM
Blue Rebel's Avatar
Blue Rebel
Ive got a thread going right now about leaking fuel injectors that isnt listed in my threads started either. something funkys going on.
As far as your problem goes, let me make sure ive got this.. start the truck by spraying gas down the TB, and then to keep it running, you need to keep your foot on the throttle... do you have to "pump" the pedal to keep it running, or will it run with the pedal kept at a certain position?
Old Mar 25, 2012 | 04:30 PM
Vinford's Avatar
Vinford
You have to pump the pedal.
When your leg gets tired and you cant pump anymore it quits ...........
Old Mar 25, 2012 | 05:18 PM
tjc transport
i ain't rite
i don't see where pumping the pedal will make any difference, because with fuel injection there is no accelerator pump.
all the throttle does is controls the amount of air going into the engine. it has nothing to do with the amount of gas going in.
Old Mar 25, 2012 | 05:29 PM
rwdfan's Avatar
rwdfan
What happens if you floor the pedal? Odd problems like this make me think vacuum leak. I would check all of your vacuum hoses that you can, make sure none are visibly broken, cracked, or disconnected. You also need to pull codes from the computer. I wouldnt think it is the fuel pump relay personally, if you can hear the fuel pump running when you stick the key to the start position, and if you can hear it running steadily while the truck runs...I wouldnt think fuel pump relay. But, you can swap it with the horn relay in the power distribution box and see if theres any change.
Old Mar 25, 2012 | 05:38 PM
Vinford's Avatar
Vinford
Maybe your on to something , its not fuel related its air.
It dies rightaway if you dont pump it.
Old Mar 25, 2012 | 05:39 PM
Vinford's Avatar
Vinford
I put a code reader (Cheap one) on it and it doesnt read any codes.
Fuel pumps working.
