Speed density doesn't use a mass airflow sensor in the intake tube. If your intake from the airbox to the intake on the moor has 2 tubes running the whole distance then you Have the speed density
Speed Density is the older version of EFI that Ford used. Mass Air Flow takes a reading of the amount of air entering the engine and adjusting the amount of fuel to match accordingly. It allows the engine to adjust to changes, and keep itself in tune. Speed Density uses a narrow preset calibration range from the factory of what the amount of air entering the engine "should" be, and can only adjust the fuel amounts slightly to match that range.
And that could make it not run?
It doesnt run badly .....it runs good when your pumping it.
Speed Density is not a specific sensor, its a system. If there was too much modification done to the engine, it would not run. By modification i mean bored, stroked, or aftermarket heads. just putting an exhaust on would not cause problems.
