someone help me please
i have a 2004 f350. i parked the truck on a jersey barrier about 3 weeks ago and i havent had an issue until last night. i have hids, led running lights with resistors in the front. im having some crazy electrical issues with the truck. it started with no brake lights or running lights in the rear when my head lights are on. when the head lights are off they are fine and work normal. i found a crushed wire in the rear under the bed for the right rear side. now the cab lights flash when the right directional is on if it decides to not stay on all the time. the left front running light doesnt work unless i move the wires around then the mirror running light and directional come on and stay on. anyone have any idea what could cause this? what it might be?
Do yourself a favor and start by removing your HID's and going back to stock. Maybe even disconnect your LED's for now. Fix any bad wiring you find. Then see if your problem is still there. Did you install these yourself? If so, it should be easier for you to retrace your steps.
The front what? Led's? Hid's? Lights? If you installed these yourself, remove wherever you spliced for ground and positive and check again. If you found a wire pinched, as you stated, chances are there is more of them. The problems you are having all point to wiring, not components. You will have to be patient and work your way thru the wiring. Start with the area you find that "crushed" wire. Do you know if the truck was in an accident? If so, do you know what part of the truck was in the wreck?
I took all of the wiring and lights that I added and started from there. I hit a jersey barrier with the passenger side rear about 3 weeks ago. That's where I found one wire pinched and im gonna start there again today and work toward the fron of the truck. Why would it only happen when the running lights are on though?
tooldad1041
1999 to 2016 Super Duty
17
12-12-2014 05:40 AM
WV2004
04-11-2013 02:09 PM
