adding coolant
Old Mar 22, 2012 | 08:44 AM
TJK1's Avatar
TJK1
adding coolant
I just finished flushing my coolant system preparing for an oil cooler change. Had deltas of 15 to 20, after flushing many times over the past week and using vc9 the delta is now 8 to 10, my question is how much will adding the coolant change the temp? I know just water transfers heat better but how much.
Old Mar 22, 2012 | 09:39 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
As the differencial will be the same, I doubt if it'll bother the delta. It shouldn't change more than a degree or two. My concern is what caused it to begin with. The oil and EGR coolers may still give you problems.
Old Mar 22, 2012 | 10:08 AM
pappy42's Avatar
pappy42
I think that many folks on this site would be interested in your results (re deltas) over the next several thousand miles; I know that I would.
Old Mar 22, 2012 | 11:09 AM
Snuggyworm's Avatar
Snuggyworm
yep. i wold tink it's the egr cooler or oil cooler or both. while i'm in there, i might also change the oil cooler screen, change to updated stc fitting, change out standpipes and dummy plugs. just to ensure she dont "burp" again.
green_95
Jul 5, 2019 02:07 PM
B846B
Jun 9, 2012 10:11 PM
robert421960
Aug 25, 2011 07:49 PM
OneTon4Fun
Dec 6, 2010 11:10 AM
SqueeK
Sep 10, 2009 01:20 PM
