7.3 engine r&r
Old Mar 22, 2012 | 12:32 AM
Iam4x4's Avatar
Iam4x4
7.3 engine r&r
Hey guys thinking of replacing my motor has a knocking sound so I'm assu
Ing it's the rod bearings got messed and so did the crank. How long should it take to do a engine remove and replace? And also labour costs if anyone knows?
Old Mar 22, 2012 | 12:37 AM
BigAlsPSD's Avatar
BigAlsPSD
Not too hard of an R&R. Did my last in a weekend. No idea on labor though...
What led you to rod bearings? If you are driving it with the torque converter locked around 45ish and you let off, does the knock go away?
Split injector nozzle or bad injector can sound like someone beating on the block with a sledgehammer.
Old Mar 22, 2012 | 10:40 AM
timmyboy76's Avatar
timmyboy76
Thats good info right there, Al...IF (in general) a split nozzle occured, besides the sledgehammer sign, is there any other side-effects from it?
Old Mar 22, 2012 | 01:13 PM
BigAlsPSD's Avatar
BigAlsPSD
Generally a split nozzle is accompanied by white smoke out of the exhaust. Even without a bad nozzle bad injectors can hammer pretty bad depending what goes bad.
Old Mar 23, 2012 | 12:54 PM
timmyboy76's Avatar
timmyboy76
great, good to know, thanks Al.
Old Mar 23, 2012 | 01:14 PM
Iam4x4's Avatar
Iam4x4
The noise is coming from the back of the motor. Ive heard it could be the flexplate and torque converter
Old Mar 23, 2012 | 01:36 PM
DemonRace6's Avatar
DemonRace6
Hi!
My knocking sound came from a broken rocker and bent push rod. When did the knocking sound start?
Old Mar 24, 2012 | 02:34 PM
Iam4x4's Avatar
Iam4x4
I just posted a video on YouTube of the engine knock. It is posted as 7.3 powerstroke Knock? My user name is 666drummer4 and I posted it 5 minutes ago sorry I could not just post a link straight to it, my phone is acting up and that's how I posted it
Old Mar 24, 2012 | 02:43 PM
Iam4x4's Avatar
Iam4x4
7.3 powerstroke knock? - YouTube
Is the link
Old Mar 24, 2012 | 06:08 PM
PaulDH's Avatar
PaulDH
IF you spun a rod bearing, the knocking will get substantially louder over the duration of as little as 50 miles of driving, as the crankshaft rod bearing journal surface continues to wear away, increasing the size of the gap between the crank journal and the rod bearing housing. That was my experience when I spun a rod bearing on a 6.2L Chevy Diesel. An oil cooler hose blew while my wife was driving the vehicle. Puked out all the oil and she drove it about 1.5 miles at 20 mph prior to parking and calling me. Too late. The damage was already done. I replaced the failed hose, filled it up with fresh oil, and drove it for maybe 50 miles. The knocking noise was initially very subtle, but continued to get worse and worse, until I finally accepted the fact the gig was up and pulled and rebuilt the engine. The rod bearing journal surface on my crank was shot. Probably 1/8" in diameter was already worn away in just the first 50-70 miles of driving.
Old Mar 24, 2012 | 09:58 PM
Iam4x4's Avatar
Iam4x4
The knocking stays consistent when I drive the noise does not stop at any speeds. And also increases in speed with truck and smells like oil is leaking or diesel
Old Mar 24, 2012 | 10:14 PM
bulla's Avatar
bulla
Wow! That is pretty noticeable. Have you looked for blow by? Might consider pulling the valve covers for a look. No smoke? Strong diesel smell? Big truck by the way!
Old Mar 24, 2012 | 11:07 PM
Iam4x4's Avatar
Iam4x4
Thanks man. I recently purchased this truck I have been known for a lot of these jacked up 7.3. I took it for a drive and when the chip is on it burn alot of black but web off (and not very cold) and the smoke was greyest white. And I just noticed in the video that it looks like there is some fuel on the oil filter also. Tomorrow I'm planning on taking the valve cover off tomorrow and see if it is indeed an injector or maybe a rod
Old Aug 27, 2012 | 10:08 PM
rgarcia1104's Avatar
rgarcia1104
What was the outcome to your problem? I'm having the same issue can't seem to find the problem.Pulled off valve covers, found milky liquids, water going to oil pan. I'm really hoping I don't have a bad motor.Please help!
Old Aug 27, 2012 | 11:16 PM
Iam4x4's Avatar
Iam4x4
Yeah was a spun bearing
