400m timing specs?
Old Mar 21, 2012 | 10:46 PM
joel79ford's Avatar
joel79ford
400m timing specs?
where is it supposed to be at right now? i have it on 10 degrees
is that right? would i hurt it if i kept it there?
bone stock 400m
Old Mar 22, 2012 | 05:54 PM
crsmiffy's Avatar
crsmiffy
If it doesnt ping and it starts well (very important) and runs fine is probably OK.
Old Mar 23, 2012 | 08:57 AM
joel79ford's Avatar
joel79ford
Originally Posted by crsmiffy
If it doesn't ping and it starts well (very important) and runs fine is probably OK.
What do you mean "ping"?
like if it sounds that its struggling to stay on?
the rpms are pretty low when its in neutral or when i come to a stop
oh and it does start pretty hard, like it struggles to stay on but i have a feeling that its a vacuum hose problem
Old Mar 27, 2012 | 05:11 PM
crsmiffy's Avatar
crsmiffy
pinging is commonly called detonation, but after I read a post a while back that had two good links on detonation/pre-ignition etc (in stickies by the way-worth a look), I have revised that but for now it's probably still enough in this case. It's a "knocking" noise that you usually encounter when you either have too much advance or you lug the engine down low in the revs in too tall a gear/uphill with a load etc. sounds a little like a deisel knock
cornfeed
Dec 17, 2008 02:01 PM
hevy metal
Dec 26, 2007 08:10 PM
stgdive
Dec 3, 2003 09:09 AM
Rat wagon
May 20, 2003 11:19 PM
fishmanndotcom
Mar 14, 2003 10:00 PM
