Head gaskets/Dummy plugs
Old Mar 21, 2012 | 07:51 PM
grantpage's Avatar
grantpage
I am changing the head gaskets soon, and am wondering if I need to change dummy plugs? or what else I need to do while I am in there. If I read correctly the 03 engines do not need dummy plugs? Was there a certain engine build date?
Old Mar 21, 2012 | 09:22 PM
BLADE35's Avatar
BLADE35
If Im not mistaken here you have Dummey Plugs IF your ICP sensor is in the Passenger side valve cover which means you will have the Wavey OIL Rail
If ICP is under Turbo then no dummey plugs I guess I shouldnt say no plug cuz IIRC they did have a Plug in the early Log Oil Rails but it not problematic Its Been a few since I had my Log Oil Rails out so dont quote me on the early rail plugs
you will also want to replace any orings you disturbed on the standpipes
Old Mar 21, 2012 | 09:47 PM
grantpage's Avatar
grantpage
I replaced the icp sensor a few months ago, it is behind the turbo. If the dummy plugs are fine, then is there anything else to replace while I am in there?
Old Mar 21, 2012 | 10:11 PM
BLADE35's Avatar
BLADE35
there sprobably some Orings you could replace when uyou unhook the standpipes to get the Heads out
also would be a good time to add exhaust manafold gaskets since they did not come with them from factory
Man I mised you said it an 03
rering all injectors
oil cooler to if you need it
turbo hardware/gaskets kit
Old Mar 22, 2012 | 07:12 PM
grantpage's Avatar
grantpage
Is there an updated stand pipe? I replaced the oil cooler and installed egr delete about 6 months ago. How about the blue fuel pressure spring?
Old Mar 22, 2012 | 08:52 PM
BLADE35's Avatar
BLADE35
Yep might as well do the Blue Spring mod
and a coolant filter
h20ford
Mar 20, 2013 11:27 AM
kornfanjoe
Jul 26, 2012 04:32 AM
runinbear
16
Dec 31, 2007 01:11 PM
Mochajones
Oct 31, 2006 11:47 AM
94inline6
May 11, 2006 11:06 PM
