Ford Ring gear Problem (New member)
Old Mar 21, 2012 | 04:28 PM
needhelp49's Avatar
needhelp49
i think its hard to find alot of parts for the 226
Old Mar 21, 2012 | 06:35 PM
oldmerc's Avatar
oldmerc
oldmerc
I can offer no more advise than what you have already received , but I will extend my welcome and wish that you find enjoyment with your new acquisition .
Old Mar 22, 2012 | 08:22 AM
Kristof's Avatar
Kristof
Just had mail from Joblot,they also can't deliver them anymore.
Somewhere there has to be one with my name on it. I found a store that can get one but there price is ridiculous.
Old Mar 23, 2012 | 04:56 AM
Kristof's Avatar
Kristof
Could someone help me with making a call?
I got the info that a while ago someone had a few of these ring gears in his stock. But I can't find any email contact,only a phone number.
This would be the man in question:
Al's Flywheel Ring Gears
Al Suehring
10058 Krogwold Road
Amherst Junction, WI 54407
715-677-3809<!-- google_ad_section_end -->
Greetings Kristof
Old Mar 23, 2012 | 07:21 AM
harleymsn's Avatar
harleymsn
I though maybe NumberDummy would have been through here by now, he's probably your best bet for finding one.
Old Mar 23, 2012 | 07:56 AM
BACAGrizz's Avatar
BACAGrizz
I'll call him for you later this morning when they are open.
I placed the call this morning. Al was out but his wife took the info and will have him call me when he gets in.
Looking at the old ring gear, if you can't find one right away you may be able to flip it around and let the starter engage the other side where the teeth are still good for a temporary solution.
Old Mar 23, 2012 | 10:40 AM
Kristof's Avatar
Kristof
Thx a million for helping me ,i greatly appreciate it Let's hope he will have one.
And normally I would think about turning it over but here's the problem.
When we took everything apart it turned out that the starter was just loose , and because of that the starter damaged the ring gear all around sadly enough.(and the damage is pretty extensive)
Old Mar 23, 2012 | 11:33 AM
BACAGrizz's Avatar
BACAGrizz
Good news. He has a couple of them. They are $85.00.
His e-mail is al@suehring.com
Good luck!
Old Mar 23, 2012 | 11:51 AM
Kristof's Avatar
Kristof
Good luck!
Thank you!! I mailed him immediatly!
If I can ever help you, you can count on me
Old Mar 30, 2012 | 11:30 AM
asidpara's Avatar
asidpara
1967 Flywheel Ring Gear
I did find replacement gear but have not ordered. Can someone tell me how it is installed? In the picture, I do not see any bolt holes. The shop manual does not show either. I will appreciate prompt response.
Old Mar 30, 2012 | 12:06 PM
Kristof's Avatar
Kristof
If it's like mine (a sepperate ring) then you have to heat up the ring until it reaches a certain temperature that it expands a bit and the ntap it off. Same to place new one.
For the people that where following my problem, I ordered 2 brand new 114 tooth ring gears for my ford 226!
Again thx to BACAGrizz for calling Al's!
Greetings Kristof
Old Nov 2, 2013 | 08:35 PM
mossyoak1992's Avatar
mossyoak1992
Hi sorry to bring back an old thread but I have a 1948 ford f1 with the 226 and ordered a ring gear from al to come to find out I have a 112 tooth ring gear and not the 114 that I believe I am supposed too is it possible that ford may have used a g series flywheel and ring gear on my h series motor due to the research I have done is that they had a 112 tooth ringgear
Old Nov 2, 2013 | 09:19 PM
  #28
harleymsn's Avatar
harleymsn
OK, from the parts book, 48-51 had the 114 tooth ring, BUT in 48-49 they also had the 112 tooth ring. The 112 tooth has a very different part # from the 112 tooth in the V8.
Old Nov 2, 2013 | 09:40 PM
  #29
mossyoak1992
Thanks for that link now the golden question is do you know of any available I will call al tomorrow hopefully he will have one
Old Nov 2, 2013 | 11:15 PM
  #30
ALBUQ F-1's Avatar
ALBUQ F-1
It looks like the difference is whether you have a 10" or 11" clutch. Do you know which you have? What trans do you have? Usually the 11" only comes with the HD trannies in F-1's.
