stage 1 injector question
Old Mar 21, 2012 | 06:08 PM
superduty4x4's Avatar
superduty4x4
Originally Posted by f350rebel7788
Reeeeeeaaalllly.... well I guess I know what my next upgrade will be! I'd rather get it before it gets me, cause knowing the timing I have, I'll upgrade injectors and it won't go out when convenient... lol
FWIW, I noticed no difference when swapping to a modded 17° HPOP in either Whitey or PDE. Don't expect a huge change from the HPOP.
Old Mar 21, 2012 | 06:32 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by deadsenator
So, I am trying to understand the duty cycle on the pump. I've been monitoring the PSI and %DC numbers but I do not ultimately know what they mean.
Putting my foot in it, I get ~30%DC and ~2200psi. What should I be looking for? What tells me my 15° HPOP is either tiring out or at its limits?
If your only getting to ~30% DC, your tuner isn't asking for 3000psi of ICP, in an attempt to keep you from setting the CEL and codes.. If you were calling for 3000psi and only holding ~2200psi, the DC would rise to 50+% in an attempt to get the pressure up to what the tuning is asking for. If you call for ICP and cannot hold pressure even at 50+% DC, you will set the CEL and trip a code.
Old Mar 21, 2012 | 06:47 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
Gotcha... my big thing is i'd rather have overkill on things like cooling and fuel supply than power and performance...
Old Mar 22, 2012 | 09:19 AM
superduty4x4
Copy, I just didn't want you thinking that swapping to a T500 HPOP was going to make this remarkable difference then have you be disappointed when the change is very small to completely undetectable.
Old Mar 22, 2012 | 10:44 AM
f350rebel7788
I appreciate that! Lol I think from everything that I understand, the HPOP is one of those behind the scene things... you don't really pay attention to it and it doesn't make a difference until it quits workin lol
Old Mar 22, 2012 | 04:54 PM
427 fordman's Avatar
427 fordman
That's why I said MAY notice a BIT more power. Like chase said, maybe, maybe not, but not a lot for sure.
Old Mar 22, 2012 | 07:11 PM
deadsenator's Avatar
deadsenator
Thanks Travis. That helps. I switched to my tow setting and it hit 2500psi at one point. I need to mess with the gauge settings so I can catch the numbers easier.
Old Mar 22, 2012 | 07:44 PM
Talyn's Avatar
Talyn
If your injectors want more oil than your pump can supply, you'll never see their potential.
and upgraded hpop will make a difference, however you might not ever notice it with the butt dyno.
Nabors
Oct 23, 2014 03:43 PM
bkuuz1
Sep 13, 2013 09:53 AM
BigfootIDI
Apr 10, 2010 03:19 AM
tholt34
Apr 13, 2008 12:10 AM
wolfe1104
21
Mar 5, 2008 09:21 PM
