Coolant block plug problems
Old Mar 21, 2012 | 06:02 PM
oldbird1965's Avatar
oldbird1965
Wouldn't it be easier to remove the front tire and the inner fender lining to help get at it? Sorry about all the questions.
Old Mar 21, 2012 | 06:32 PM
YoungFordAddict66's Avatar
YoungFordAddict66
No its ok. Yea i thought about removing the tire a little late, i already had the cherry picker's legs under the front end and didnt have any where to easily and safely lift the tuck. But i would remove the front tire to make it easier to get to. I did remove the little inner fender piece behind the shock, that allowed me to get to the front bolts and be able to grab th front of the cooler. I didnt remove the whole inner fender lining, seemed like one more thing i didnt want to take off.
Old Mar 25, 2012 | 06:17 PM
Desert Rancher's Avatar
Desert Rancher
The factory plugs are an internal 1/4" and they are tight. there is one on the drivers side rear and one behind the starter. I had to use a small air impact wrench to remove them. Both must be removed to completely flush and drain.
Replace them with a brass hex head, 1/4 npt pipe plug and you will never have a problem again.
~DR
Old Mar 25, 2012 | 11:04 PM
YoungFordAddict66
I said f*&^ it to the drivers side even after soaking it with pb blaster, but got the passenger side bolt out. The water came out clean after the garden hose flush, so im not worried about left over green stuff.
Obs7.3Powerstroker
Feb 12, 2019 01:01 PM
bballcrf
Nov 19, 2011 08:28 AM
dieselaholic
13
Jul 3, 2011 09:23 AM
funford
1997 - 2003 F150
Apr 12, 2006 07:41 PM
Aftrmidnite
1997 - 2003 F150
Nov 5, 2004 04:23 PM
