Coolant block plug problems
Old Mar 20, 2012 | 03:44 PM
YoungFordAddict66's Avatar
YoungFordAddict66
Ok so.im trying to flush my coolant and am having some trouble with my coolant block plugs. The drivers side doesnt want to budge, its soaking in wd-40 so im hoping it will come out before it strips. But my paasenger side one above the starter seems to be a bolt. Now im debating whether or not to remove the starter to get a closer look. Should i try and remove this bolt or do I have the wrong plug? I cant find any other plugs above the starter let alone a 1/4" one.
Old Mar 20, 2012 | 04:19 PM
BlueMule's Avatar
BlueMule
Mine also had two different type plugs in the water jacket, a hex head plug near the starter and a 1/4 drive style on the drivers side. Try something besides WD40, it's not a real penetrating oil. Kroil is my favorite but no one around here carries it and I have to do an internet order. PB blaster and Liquid Wrench work ok and are readily available.
Old Mar 20, 2012 | 04:28 PM
redman84's Avatar
redman84
x2. PB Blaster works pretty well for something you can get anywhere. And you can get it anywhere from a little small can to a bulk jug. I used one can of liquid wrench and it worked fine but I REALLY hated the smell of it. It's like burnt hair and hairspray. If you have the time spray it good every now and again for a day or more and then get after it.
Old Mar 20, 2012 | 04:34 PM
YoungFordAddict66
Well i soaked it a couple times before i took off for my finals and by the time i get home all the auto parts stores will be closed. So I 'll give them a try when i get home and if they dont want to come out then they will stay put cause i need my truck tomorrow. I mean u wont be hurting anything when i flush it and dont pull the plugs right? I got the flush kit.and about 20 gala of distilled water, enough for two flushed and then the final top off with the fleet charge.
Old Mar 20, 2012 | 06:28 PM
427 fordman's Avatar
427 fordman
You're not gonna hurt anything by not getting the plugs out, but you will leave about 2 gallons of old antifreeze in there, and you won't get it all out without removing the plugs imo.
Old Mar 20, 2012 | 06:50 PM
YoungFordAddict66
Ok well i got home early and got the passenger side out and got about a gallon but the drivers side wont budge so its staying in. What hose do i cut into to place the flush t? The one off the block is to short and wont come off the fitting, maybe 6" and curved so i know it wont seal right. I was thinking about the one that comes off that t, near the hose from he block, and heads down towards the radiator. And do i need to put red loctite one the threads again cause thats what looks like was on it.
Old Mar 20, 2012 | 07:11 PM
YoungFordAddict66
Or should i T into the hose that goes to the heater core coming from the the T that feeds the block? If that makes sense.
Old Mar 20, 2012 | 11:50 PM
oldbird1965's Avatar
oldbird1965
Have you done that cooler yet Blake?
Old Mar 21, 2012 | 12:20 AM
pjwoolw's Avatar
pjwoolw
I wouldn't use red LocTite on anything that may need to be removed again. Thats threaded anyway. A thread sealant like Bob's Gasoila would be fine on those plugs.
Old Mar 21, 2012 | 12:54 AM
YoungFordAddict66
Yea i did the oil cooler yesterday, man those rear orimgs were so hard i thought they were metal. And im on my last flush of distilled right now, then i'll be adding coolant.
Old Mar 21, 2012 | 01:08 AM
oldbird1965
Was it hard to get out of there?
Old Mar 21, 2012 | 01:43 AM
YoungFordAddict66
Yea i was fighting with it for about 30 minutes or so and couldnt get it out no matter which way i twistes. Then i got a tip, that raising that side of the engine about an inch or so with a cheery picker would help. So i did ane it almost fell right out. Then getring it apart was easy, and putting it together wasnt to hard, just used a jack and put it against my rear bumper since i dont have a press.
Old Mar 21, 2012 | 04:09 AM
YoungFordAddict66
I used liquid teflon. The guys at my local napa set me straight on what to use.
Old Mar 21, 2012 | 10:09 AM
oldbird1965
That's what I'm afraid of, is there a way to jake up the engine a little without a cherry picker?
Old Mar 21, 2012 | 05:06 PM
YoungFordAddict66
That i dont know. I know not everyone has to lift the motor, but i did just cause it took a couple extra minutes and made taking it out a whole lot easier than to keep fighting with it. But what i found as even when i lifted the motor it still didnt want to come out, until i leaned over the front tire and stuck my hand above the frame and grabbed the front of the cooler. Then i freed it fom whatever it was hung up on and it just about fell out. So hopefully you dont need a cherry picker.
