Oil Leaking Badly
Old Mar 20, 2012 | 03:04 PM
ArrBeah's Avatar
ArrBeah
Oil Leaking Badly
I recently had the O rings replaced on my Ford F350 7.3 HPOP. Now oil pours down the passenger side of my motor when the motor is running. Any thoughts on what could cause this. I have tried to track down the leak to no avail.
Old Mar 20, 2012 | 03:27 PM
Billyclub's Avatar
Billyclub
Try cleaning out the valley and then lay some paper towels in there and run the motor. The towel will tell you if it's up front or below the turbo pedestal. My bet is the HPOP has a O ring not seated correctly. Hopefully I'm wrong though. Somebody much more knowledgable than I will chime in shortly. Hang tight
xarons21
Dec 23, 2020 09:12 AM
Will Burcham
Dec 26, 2011 07:01 PM
przao1157
May 1, 2009 04:18 PM
matt71
Oct 30, 2008 02:54 PM
RussB
30
Jun 9, 2008 07:18 PM
