No power after cold start
Old Mar 20, 2012 | 01:53 AM
BigTruk small feet's Avatar
BigTruk small feet
Gentlemen,
My 2000 7.3 has NO power at all after starting first thing in the morning.
It starts fine, and runs fine, but if i don't let it warm up a little, it won't even move.........it like it's tied to a very large tree or something.
Is this normal?
The outside temperature is fairly mild....around freezing or a few degrees below, so nothing really extreme.
Any help will be great. Thanks in advance.
Old Mar 20, 2012 | 02:00 AM
BigAlsPSD's Avatar
BigAlsPSD
Is the EBPV sticking? I mean can you hear it...that jet engine sound?
Old Mar 20, 2012 | 02:03 AM
BigTruk small feet
EBPV????? Exhaust back pressure valve?
I don't think so, the motor sounds normal.
Old Mar 20, 2012 | 02:09 AM
BigAlsPSD's Avatar
BigAlsPSD
Yes Exhaust Back Pressure Valve sorry.
Usually you can't hear it at the motor just out of the tailpipe but you've probably heard it before to know it's not that. Usually if they are sticking it is described as if you were driving and all of the sudden it's like you flipped a switch and power is restored.
Another thought is transmission fluid levels? Too low could cause flow issues, that go away as it warms.
If you plug it in for a couple hours does it do the same thing?
Old Mar 20, 2012 | 01:16 PM
carltonwebb's Avatar
carltonwebb
I have seen some trucks during cold weather that you crank and no throttle change at all when pedal is pressed . Then as it gets warmer, when u press the pedal, it will slowly accellerate and eventually start acting normal. Is that what u are having with your truck?
Old Mar 20, 2012 | 07:09 PM
BigTruk small feet
Well no.....it's exactly as though you were tied to a fixed object........while in gear of course it will only rev so high and go nowhere.
Old Mar 20, 2012 | 07:42 PM
meierw1's Avatar
meierw1
Mine does that!
Old Mar 21, 2012 | 12:06 AM
emery72's Avatar
emery72
How long are you letting it warm up? I have to let mine warm up a good 10 to 15 minutes before it really wants to move otherwise it is really sluggish. Plugging it in helps it start easier and warm up quicker, but that doesn't help the transmission fluid when it is freezing outside.
Old Mar 21, 2012 | 01:47 AM
carltonwebb
Originally Posted by meierw1
Mine does that!
One of my trucks does that and one does not. Usually within a couple minutes of running on the one that does, it will do fine.
Old Mar 21, 2012 | 05:08 PM
BigTruk small feet
thanks for the replys guys.........anyone have any other ideas what's causing it?
Old Mar 21, 2012 | 05:16 PM
BigAlsPSD's Avatar
BigAlsPSD
Does it do the same thing if it is plugged in?
Did you check transmission fluid?
Do you have a way to monitor any live data from the PCM?
TileDude
Nov 13, 2012 11:20 PM
lowboy250
Apr 8, 2010 08:42 PM
joe paulekas
Dec 3, 2008 08:38 AM
tnbtom
Jun 14, 2005 11:12 AM
ksanders2
16
Nov 30, 2004 10:05 PM
