Need some help/info please
Old Mar 19, 2012 | 06:30 PM
luv2huntnfish's Avatar
luv2huntnfish
I have an 04 f-150 extended cab. I have a leak around the cargo light. Pulled the light out and the gasket/seal is shot. Have been on the web and can't seem to find the seal. Have checked with NAPA,LMC and local Ford dealership and can't find the gasket. They all want to sell the whole light assembly. Anyone out there know where I can buy just the gasket??
Old Mar 19, 2012 | 07:05 PM
MCDavis's Avatar
MCDavis
Don't hassle with a gasket. Get some RTV sealant from HomeDepot and seal it up.
Ford Agian's Avatar
Ford Agian
from what I have read on this forum there is no replacement gasket and the answer that has been given to others is to use a high quality clear siliconeon the light
John
Old Mar 19, 2012 | 07:11 PM
Coskid's Avatar
Coskid
Ford did away with the gasket a few years back when they corrected the issue and now all you can do is get a whole light assembly. I got the whole light but that was because I also wanted to upgrade my tail lights to LED's so it was a package deal.
Old Mar 19, 2012 | 07:41 PM
Greg B's Avatar
Greg B
You'll have to find some like material and fabricate your own gasket if that's the route you choose. That is what I would do. I won't pop for a complete new light assembly if all I need is a gasket. Just remember, if Ford was buying just gaskets from a supplier, the material is out there to make your own.
Old Mar 20, 2012 | 10:37 PM
luv2huntnfish
OK,thanks guys. If I can't buy a gasket I'll come up with something to stop it from leaking. Was thinking about doing the LED so this may be a good time to do it.
Old Mar 20, 2012 | 11:41 PM
Papa Tiger's Avatar
Papa Tiger
Make sure you get the proper resistance for the system. Ford uses resistance in the brake lights to shut off the cruise control.
Old Mar 21, 2012 | 05:26 AM
Ford Agian's Avatar
Ford Agian
I too was going to go to LED what is the correct resistance?
thanks in advance
John
Old Mar 21, 2012 | 05:28 AM
MCDavis's Avatar
MCDavis
I'm sorry, but isn't CC deactivation handled by the brake switch on the top of the pedal?
Old Mar 21, 2012 | 07:10 AM
Coskid's Avatar
Coskid
You can get a nice third brake light off Ebay for about $32 and its a combo of LED and standard bulb. I did this for mine and it was simple plug and play and have had no issue with CC after the install. I also replaced my rear tails at the same time with LED's and again it was a simple plug and play type of thing. That was about 6 months ago now.
Old Mar 21, 2012 | 07:12 AM
Coskid's Avatar
Coskid
Yeah I have to agree with Chandler here I don't think the lights have anything to do with the CC.
Old Mar 21, 2012 | 03:44 PM
M1-Havoc's Avatar
M1-Havoc
I would suggest the LED option. Off Ebay they are pretty cheap and they look good.
Old Mar 22, 2012 | 12:05 PM
Papa Tiger's Avatar
Papa Tiger
2004-2008 Ford uses resistance in the brake lights to disengage the Cruise. People who have installed LED's have found they need resistance. Also those who added a flasher from autozone had less problems with the Led bulbs. Believe the semiconductor device in the cluster uses vehicle speed sensor to control the throttle body. It is a semiconductor thing, not switches. If you instal the flasher you will also notice the blink is at a more normal speed. Without the changes many have found the cruise did not work at all. Just buying bulbs not recommended unless the semi conductor flasher unit is also installed, and rear tail light assemblies designed with LED's are best. If Using just the bulbs be prepaired.
rowdyredneck
15
Aug 6, 2018 11:06 PM
traxx808
Jun 25, 2014 06:48 PM
spkennyva
18
Aug 15, 2009 05:36 PM
STUDENT
Feb 14, 2007 03:36 AM
Icicle
Sep 6, 2005 04:30 PM
