Steering column
Old Mar 19, 2012 | 10:26 AM
Peterbilt376x's Avatar
Peterbilt376x
Steering column
Hey all, my steering column bearings have been gone awhile and they are beyond repair I need a new column... The only issue is finding a manual tilt wheel column is damn near impossible.... Would an automatic column work? Will I bolt up the same? Thanks
Old Mar 19, 2012 | 10:32 AM
DIYMechanic's Avatar
DIYMechanic
Yes it will and you can swap your internals into that auto column to make it work like it should. You have to swap the covers, the manual key release, and I believe some wiring into it, but it will indeed bolt right up other than that.
Old Mar 19, 2012 | 04:14 PM
ReBilld's Avatar
ReBilld
It's not bad to change. I wonder why those bearings go in some trucks and not others? I've had trucks with 150k and bad bearing and trucks with 350k and bearing is fine.
Hobby welder
Oct 29, 2016 07:09 AM
DuallyF350
May 12, 2015 08:12 PM
diesel_hillbilly
Texas Chapter
Jan 21, 2011 06:06 PM
dj8667
May 4, 2005 10:16 PM
bbtkd
May 27, 2002 02:44 PM
