Advice on 89 4.9 4x4 F150
Old Mar 19, 2012 | 12:23 AM
Darky's Avatar
Darky
I'm looking at buying a friend's truck. It's an 89 with the 4.9 I6, 4x4, stick shift, and 33s. It currently isn't starting. He was able to short the solenoid and get it to crank once, and once it started no problem, but otherwise it's not even cranking. No click from the solenoid or anything. The lights and stereo still get power.
He wants $400. Any advice? I'm thinking of getting it to drive around, see what kind of mileage it gets, maybe resell it once it's running. I currently also have a 73 2wd F250 and the 4wd on this one would be nice to get out into the desert to haul junk out.
Old Mar 19, 2012 | 12:36 AM
burnout400m's Avatar
burnout400m
I'd get it for $400. Absolute WORST case scenario the motor is seized and even then you can probably get your money back for it or get another engine off craigslist. Most likely it's a bad solenoid or starter.
Old Mar 19, 2012 | 05:29 AM
Southern Bronco's Avatar
Southern Bronco
I'd give that for it.
Old Mar 20, 2012 | 05:53 PM
Darky's Avatar
Darky
I've seen it drive, he delivered a mini truck camper to my house with it about 8 months ago. He had it running a month ago.
He's replaced the solenoid already and I think the starter as well. He got a new ignition module (the funky gray plug thing in the steering column) at the same time, but no difference was made.
What kind of mpgs can I expect out of it?
Old Mar 20, 2012 | 09:56 PM
burnout400m
The 33's are going to hurt the milage. A stock truck like that can get from 16-21. With those tires could be 10-15mpg. Depends on the gears and your driving style.
Lassie257
Nov 17, 2017 01:08 AM
BORDERBUM
30
May 9, 2012 02:01 PM
jimistephen
Jul 14, 2009 08:28 PM
stevetopps
Nov 11, 2007 03:10 PM
302V8Ford79
Electrical Systems/Wiring
Aug 2, 2003 11:08 PM
