Codes 243 and 611
Old Mar 18, 2012 | 03:26 PM
budawe's Avatar
budawe
Codes 243 and 611
Is it possible that the control module is overheating while the engine is idling? I've had my truck throw codes just after idling a while. Clear the codes and they don't come back. The truck just had a ton of work, turbo, heads etc. and has no problems when not towing.
Old Mar 18, 2012 | 03:56 PM
Dieselpop's Avatar
Dieselpop
P0611 FICM Fuel injector control module performance Internal FICM failure
The price of a new ficm around $1100 or you can have your rebuilt at BPD http://www.bulletproofdiesel.com/Repair_Service_for_your_Ford_6_0L_FICM_p/ficm_rebuild.htm for $300
or--- http://ficmrepair.com/ My choice
Info here http://www.fordtechservice.dealerconnection.com/vdirs/subsites/diag/6.0L_FICM_Guide.pdf
and here http://swampsdiesel.com/site/installation_instructions/pdf_instructions/FICM_Voltage_Testing.pdf
[FONT=Comic Sans MS]Testing the FICM [URL="http://www.youtube.com/watch?v=VSQ9lxr2oN4&NR=1"][COLOR=#0066cc]
pop
Old Mar 18, 2012 | 05:16 PM
BLADE35's Avatar
BLADE35
Send your FICM to ED
www.ficmrepair.com
He will take care of you I beleive alittle cheaper to depending what leval of service you get
Old Mar 18, 2012 | 06:47 PM
npccpartsman's Avatar
npccpartsman
Not sure where you got a P0243 (?) but the P0611 means your FICM needs repaired. The P0243 is a wastegate code and 6.0's don't have a wastegate.
gearjammer2008
1997 - 2003 F150
Dec 18, 2008 04:06 PM
MuddyAxles
New York Chapter
Sep 7, 2007 05:40 AM
90BRONCOII300,000
Bronco II
38
Feb 22, 2007 10:32 AM
Ford Roughneck
Nov 28, 2004 08:38 PM
