cleaning my engine.
Old Mar 18, 2012 | 02:09 PM
Jamie Arceneaux's Avatar
Jamie Arceneaux
Question cleaning my engine.
I have an early 99 7.3 and I do not think the engine compartment has ever been cleaned. It looks like crap. I want to get it clean so I can start looking at what I might need to mod first. What do I need to cover, avoid getting wet, Avoid hitting with the simple green, etc?
Old Mar 18, 2012 | 02:11 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Cover your alternator, battery, and air filter if its exposed. Simple Green is slightly corrosive so be sure to get it all off.
Old Mar 18, 2012 | 02:21 PM
Tailgate77478's Avatar
Tailgate77478
Don't forget to cover the power steering fluid and brake fluid reservoirs' caps too.
Old Mar 18, 2012 | 02:24 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I've never heard of that being a problem...
meierw1's Avatar
meierw1
I would suggest using a weed sprayer. I take dawn and some hot water and go to town.
Old Mar 18, 2012 | 02:38 PM
binuya's Avatar
binuya
There's a vent hole in the power steering reservoir cap where water can get in.
Old Mar 18, 2012 | 03:01 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I have pressure washed my truck engine several time as well all my vehicles through the years and those of friends, I have nover covered anything. I run the engine to warm it up, then I spray the heavy grease areas with a good degreaser, let it set and then blast away with hot water or pressure washer. Of course I don't blast the crap out of the above mentioned items and I have never had a problem. It is no different then driving freeway speed througha heavy downpour.
Old Mar 18, 2012 | 03:12 PM
bulla's Avatar
bulla
Then why don't our engines stay clean in a rainy season? Lol. But yea I've had luck just washing without to much precautions and so far it's worked out.
Old Mar 18, 2012 | 03:30 PM
hammer65's Avatar
hammer65
I would do what tailgate says, unless you might want to flush your PS Fluid.
Old Mar 18, 2012 | 07:51 PM
Tailgate77478
I appreciate the props. Yes, a little plastic wrap and a rubber band is all you need to cover it. Two minutes of labor to save the headache of getting water in your PS fluid seems like a no-brainer to me. If you are using a pressure washer, you really should do that.
Old Mar 18, 2012 | 08:44 PM
riverrat41's Avatar
riverrat41
Them alternators are high dollar,I would cover it with a Walmart bag.
rjfetz1
Sep 25, 2012 06:28 PM
Supercab
Appearance & Dress-Up
Jan 2, 2012 07:37 AM
SILVER STROKE
Jun 30, 2007 07:26 PM
Offshor3
Feb 16, 2007 08:02 PM
Bigtrucknuts
Sep 4, 2006 07:04 PM
