DC power alternator
Old Mar 26, 2012 | 05:49 PM
lakewood's Avatar
lakewood
Just installed my Dc power alternator today, installation was pretty easy and everything works great. I have two questions though:
1. I tried turning the pulley on the dc alternator and i could feel resistance as the diodes rubbed together, when i took the stocker off and turned it it had no resistance and felt like a well greased bearing, What makes the resistence different?
2. My belt is squeaking now, i think my greasy hands are the culprit, should i use belt dressing to see if it helps? the belt only squeaked when it was cold.
Thanks
Old Mar 26, 2012 | 06:24 PM
69cj's Avatar
69cj
Thanks
1. Diodes don't rub together. They are electronic components. The only rub should be brushes on the slip rings. New bearings or bushings, whatever's in the alternator, could feel tighter than the old worn ones.
2. Belt dressing is a no-no. Just squirt a little water on the belt while it's making the noise. If the noise stops you have the culprit.
Old Mar 26, 2012 | 06:28 PM
lakewood's Avatar
lakewood
Thanks for schooling me in electronics like alternators, im clueless there.
And ok water it is, thats why i asked before i acted
Old Mar 26, 2012 | 07:10 PM
BLADE35's Avatar
BLADE35
The DC Power alternator has a Smaller Pulley thats the sqweak
the smaller pulley lets it produce more power at Idel
Now in therory the belt tensioner should make the belt tighten up But maybe your belt is stretched/worn beyond spec and needs to be replaced anyway
try a belt maybe a tensioner
I know with the XP alternators (250/270 amp) they send a Shim but the 185/190 amp units shouldnt need a shim
Old Mar 26, 2012 | 07:17 PM
69cj's Avatar
69cj
You could also try putting the original pulley on the new one. I've heard of some people doing that.
Old Mar 26, 2012 | 07:26 PM
BLADE35's Avatar
BLADE35
Really your Kidden Right ??LOL
Thats like taking the High preformance out of it
That is taking the high preformance out of it IMO you want more Power at Idel as you start it up and it warms up for a few minutes you need to recover the Big Energy drain from the Glow Plugs
Old Mar 26, 2012 | 07:29 PM
BLADE35's Avatar
BLADE35
I would shim it before I would change out the Pulley
That would be like unpluging a couple injectors on you truck to make it a 6 cylinder LOL
Old Mar 26, 2012 | 07:59 PM
lakewood's Avatar
lakewood
Squeak didnt happen on the second start up but the truck was a little warm, we'll see how it goes next cold start. As long as it only squeaks when cold im ok with that.
Old Mar 26, 2012 | 08:44 PM
BLADE35's Avatar
BLADE35
Its probably ok the tensioner probably had a spot it liked to ride in in the last setup and with the new setup/smaller pulley it just had to seat itsself in a little dif spot
you shouldnt change the pulley its smaller so you can get that higher AMP output at Idel this is not an option IMO
Old Mar 26, 2012 | 08:58 PM
bismic's Avatar
bismic
I am really pleased w/ my DC Power unit. I can get 200A at idle!! More than enough to charge the spare two batteries and run the Power Inverter!!!
Old Mar 26, 2012 | 09:01 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
My belt squealed after changing the alternator in my 03 V10 van. Water didn't work for me, but blaster dry silicone spray worked for me!
Old Jul 8, 2012 | 04:51 PM
berick's Avatar
berick
When I talked with them the wire upgrade is recomended I got the wire upgrade for free from them so IDK how much they charge for it.
Its Not a Big Deal you can Make your Own Basicaly its just a Battery Cable with a Fuse inline with it
Check my pics out and just make your own
Ford Truck Enthusiasts Forums - BLADE35's Album: DC Power Alternator & Wire Upgrade
Notice the red battery cable there is a grey part of the wire right where it bolts to the Alternator thats the Fusable link. Not shure of the rating of it. But High Binder also made his own wire upgrade and he said they told him to run an 250amp fuse in that line But IIRC he got the 185 or 190amp alternator so why they told him to install a Fuse thats more then the Output rating of the Alternator is Beyond Me seems like you would want the Fuse to be at or just a touch under the output rating of the Alternator
IMO call DC power and ask them what fuse to run and if they tell you to put a fuse thats rated more than the Alternator output ask them why I would like to know myself as I dont get it
I also recomend to take a dremal tool and clean all battery cables and Grounds up good
thanks Lakewood
Hey Blade,
I just ordered a DC XP270 from the July 4th sale they just had and I ordered the 1.0 wire harness upgrade kit with fuse as well (they said it should definitely be done or the factory wiring would likely fry). I also ordered the military style terminals as well because he said they were a great improvement from what's on the truck now. My question is this.... the wiring kit is a cable increase to 1 gauge but it only goes to one battery. Shouldn't the wiring going to the second battery for charging also be upgraded to 1 gauge?
Old Jul 8, 2012 | 10:48 PM
  #28
BLADE35's Avatar
BLADE35
Originally Posted by berick
Hey Blade,
Well they dont do that if you wanted to it wouldnt hurt
They tell me in therory they already hooked together and what there is good enough
but you can do it if you want just make your own wire thats what I would do they just gave mw the wire upgrade for free cuz they had a website issue that day I was emailing him the Bad link so he could fix it so they threw the wire in for me
If I would have had to buy the wire upgrade I would have made my own
Old Jul 8, 2012 | 11:10 PM
  #29
Special Ed's Avatar
Special Ed
I just ordered a 185 on Friday after seeing my voltage dip into the high 11's. Cant wait to get my hands on it. I was also advised to upgrade the cables with the smallest one they offer.
Old Jul 9, 2012 | 01:03 AM
  #30
lakewood's Avatar
lakewood
Im glad this came back up, mine is still charging fine but the pulley on it squeaks terribly when cold
