1991 speedometer drive gear
I just put a M5OD 4x4 transmission and transfer case in a 73 f100 and the speedometer wasnt working after i got a new cable and i determined that the drive gear(the one inside the t-case) was bad. I could see that in the center where the driven gear contacts was work down so far that they wouldn't make contact. How do i go about replacing it? do i half to split open the t-case? And where do i get the gear from? I tried my local Napa, both advances and auto-zone and no one could come up with one or even a part number for me. Or would it be worth it to just take it to a shop and let them deal with it? Thanks in advance, Jon.
If this helps at all these are the numbers off the tag on the transfercase: F0992 1345-39 103916 E9TA-KG.
Rebuild Kit 1345 Transfer Case Borg Warner and Parts Illustration and parts list! - Drivetrain.com Have a look here for diagram and parts. Would need to split the case.
wharthog
Dec 31, 2016 06:22 PM
rbrungard2012
Dec 6, 2013 12:30 PM
Chuky66
Sep 26, 2005 11:37 AM
77hb
May 24, 2005 07:45 PM
