Bad Engine Noise
Old Mar 17, 2012 | 06:45 PM
PEARLOFTHEDESERT's Avatar
PEARLOFTHEDESERT
Bad Engine Noise
Hey guys, so recently I've ran into this noise under the hood and not sure what it is. There was always an exhaust leak that sounded like it was escaping from the doughnut and now this!? I do know that this only sounds off when the engine has been running for a while or when i give it a lot of gas. It does sound like a ticking more than a "pfffttt" Ideas? 78 f250 7.5 - YouTube
Old Mar 17, 2012 | 06:51 PM
HIO Silver's Avatar
HIO Silver
I assume you are referring to the ticking sound.
Seems RPM related so I'd take a look at the valve train. Could have a loose rocker, a lazy lifter, or a weak valve spring.
Old Mar 18, 2012 | 10:24 PM
coinrims's Avatar
coinrims
bought a 78 f350 engine smoked had a noise on pass side thought it was a lifter but i was changing engine anyway took off exhaust pipe and looked down pipe. when they welded drop pipe to y pipe they only cut a 3/4 inch hole so 4 pistons were pushing through the 3/4 inch hole the truck only 87000 so shouldnt have been smoking yet.
nexus1467
Feb 17, 2016 05:58 PM
crazymut
Dec 19, 2009 09:40 AM
caleb6.9
Nov 27, 2009 04:03 PM
srumble
Nov 19, 2007 01:19 PM
bigbadwolfe
Aug 9, 2007 06:35 PM
