Ford 400 block problem
Old Mar 17, 2012 | 06:18 PM
johnson2007's Avatar
johnson2007
I removed my intake manifold to replace the leaking gasket and saw this hole at the end of my block right below the distributor. This is a reman'd block that is about 4 years old and has about 20,000 miles on it. The hole looks like something punched through it as it is not smooth. Anyone know what this could be from or if it is causing problems? I had a timing chain break on this engine and am wondering if that caused the hole. Please help!
Old Mar 17, 2012 | 08:28 PM
393STROKER's Avatar
393STROKER
They all have it.When they cast the block they punch it out to let oil get to the cam gear.
Old Mar 17, 2012 | 08:45 PM
johnson2007
Even the third hole that's kind of on the side wall farthest up in the picture? I know the two perfectly round holes are supposed to be there, but the third hole on the wall isn't round and its actually pretty sharp.
Old Mar 17, 2012 | 09:03 PM
393STROKER's Avatar
393STROKER
Yes, I hit it with a die grinder to smooth it out when I have the block torn down.Don`t worry it`s suposed to be there.
Old Mar 17, 2012 | 11:56 PM
wyoming4x4's Avatar
wyoming4x4
normal stuff.
like mentioned hit with grinder if you tear it down and prep for overhaul. their are several places that can be touched up on with a grinder if you start lookin at these blocks. anything you can do to help get oil back into the oilpan as quick as possible is a good thing on the drain holes.
Old Mar 18, 2012 | 05:53 PM
crsmiffy's Avatar
crsmiffy
x2 on all comments. took much of the casting surface off and rough polished my valley and also opened up the oil drain holes and all but removed the little dams on each end. struggling to put photo on here but may be in my profile for a look. That photo shows the oil hole you mention (if it worked) LOL.
TMI
Dec 24, 2016 06:46 AM
reed1951
May 8, 2011 11:21 PM
ReAX
Modular V8 (4.6L, 5.4L)
Sep 16, 2006 07:36 PM
kelvis
Feb 13, 2006 04:11 PM
